At first "Android System" was like 25% which was okay i guess, I still felt like the battery is not so good.... it drained fast...
But today with moderate use I got from 100% at 7:00 to 5% at 17:30! (and I charged for like 10 minutes with a 1A charger which didn't help a lot)
when I checked the battery stats, "android system" was 43%!!!!
Even when im not using the device I see that the battery goes down very fast! even though I clean the apps in the background a lot!
Maybe i turend on some setting that really drains the battery?
What can I do to fix this?
I have to mention that these stats are with power saving mode turned on!
This is such a disappointment... I hope it can be fixed cuz I expected a lot more from the phone's battery..
Also - I dont know if it helps, but the devices tends to get hot even when not using it...
and the screen is almost always on very low brightness
Attached are screen shots with the detais about "android system"
