03-06-2017 04:12 AM
26 12
tools
  1. KillerKlown's Avatar
    Hi, i got my Samsung Galaxy S5 yestetday. I tried to use my Beats wireless, but they're not connecting. They work great and connect to my S3. Blue tooth is turned on on the S5, the beats are flashing red, but the phone can't find the beats. Any suggestions?
    04-23-2014 12:08 PM
  2. KillerKlown's Avatar
    04-24-2014 04:01 AM
  3. JS_racer's Avatar
    trying to pair or something ?? sorry cant help this specific issue
    i have a sony rpd-xf300 and the transition is not seamless, i have to select it from the pull down for bluetooth some times. this is after it was paired and the Sony powered on.
    04-24-2014 05:47 AM
  4. KillerKlown's Avatar
    Hi. Thanks for the reply. It's not showing up in the list when it's scanning. My Beats pill works fine, however that is NFC.
    04-24-2014 06:08 AM
  5. JS_racer's Avatar
    And it is set to pairing mode, not connected to anything around already? Might not go in pairing mode if connected to another device?
    04-24-2014 12:53 PM
  6. mr.wiggly's Avatar
    I am having the same problem with mine my gs5 doesn't even see them and i tried everything
    Sent from my SM-G900V using Tapatalk
    05-04-2014 05:48 AM
  7. brooklynnfoery's Avatar
    do you still need help? i was just having the same problem but solved it. go to your settings and click bluetooth and you have to check the box where it says only visible to paired devices and it will switch to visible to all nearby bluetooth devices for 2 minutes and then at the bottom press scan and then hold down your button on the pill and it should pop up.
    07-23-2014 12:42 PM
  8. tekogremista's Avatar
    Anyone??? I have the same problem
    09-30-2014 12:10 AM
  9. XanderonG's Avatar
    Hi KillerKlown. I just got a pair of Beats Wireless. So, what you are doing is simply turning them on into pairing mode. This is when the red light flashes slowly. What you need to do is turn your headphones off, and then hold the power button for about 5 seconds. Hold down until you see the LED blinking fast between blue and red, kind of like a police light. Then, it is in scanning mode, and your phone sould pick it up no problem.
    -XanderonG
    01-01-2015 09:11 PM
  10. eDDie-G's Avatar
    yep that last one worked.. i was so shattered when i couldn't get em to work.. thanks for posting the question and thanks for the easy answer
    01-30-2015 04:05 PM
  11. Usama Arshad2's Avatar
    Does the calling feature work right...??
    05-27-2015 08:06 AM
  12. Usama Arshad2's Avatar
    05-27-2015 08:13 AM
  13. dmagikwand's Avatar
    Call and Music Audio should both be checkmarked in the GS5 Bluetooth settings for the device. This should be the default settings though if I remember correctly.
    I have LG Tone Infinims and there is an LG app in the store that gives me more options on my headset like reading text messages, announcing the caller and such. There could possibly be a Beats app for more functionality though I've not personally checked.
    05-27-2015 07:20 PM
  14. uneek mariiposa1's Avatar
    Make sure (sync) is marked as enabled.
    Attached Thumbnails Beats wireless not connecting-screenshot_2015-05-28-15-30-20.jpg
    05-28-2015 04:33 PM
  15. cngboom's Avatar
    Thank you this worked perfectly.
    06-11-2015 03:46 PM
  16. friscog415's Avatar
    Excellent instructions. Thanks XanderonG. My Beats by Dre have been sitting up for the last 4 months collecting dust. I had to resort to some cheap Target Sony joints. When those went bad (over time the wiring gets loose and eventually you lose the connection, typically last about 2-3 months going to gym 4 days a week) I had tried one last ditch effort with the Beats to no avail until I came across this post and reply. Once again, thanks XanderonG for my Beats have risen from it's coma.
    07-10-2015 05:55 PM
  17. Dmitry Ananichev's Avatar
    just a question did the buttons on the headphones work even with android phone wireless connection????
    09-09-2015 03:30 PM
  18. Orlando Poole's Avatar
    My dr. Dre studio beats wont connect or pair with LG android and suggestions?
    Reyes7722 likes this.
    10-19-2015 07:15 PM
  19. easelizabeth's Avatar
    Your the best, it worked!!!
    05-03-2016 04:15 PM
  20. designdwellart's Avatar
    It helps to know where the power button is. It is not on the "pill" it is on the left ear bud. That worked! Thanks!!
    09-02-2016 07:43 PM
  21. steveaus's Avatar
    I have just purchased powerbeats2 wireless, my galaxy s6 says it cannot communicate with them. I have Bluetooth turned on and sync active, they show up as available but will not connect. can anyone help
    09-03-2016 08:14 PM
  22. danielataques's Avatar
    Hello, I have the same problem as you.. could you fix it already?
    12-22-2016 09:56 AM
  23. Mr Balloon's Avatar
    Hi I have beats studio and on the Bluetooth list the beats doesn't show up
    12-25-2016 04:16 PM
  24. Mr Balloon's Avatar
    I have a Android
    12-25-2016 04:17 PM
  25. Mr Balloon's Avatar
    12-25-2016 04:18 PM
26 12
  1. ok Google not working
    By tigerNamedtony07 in forum HTC One M8
    Last Post: 10-01-2014, 08:51 AM
  2. Google Images Not Loading on Verizon Galaxy Note 2
    By Taylor21 in forum Verizon Galaxy Note 2
    Last Post: 05-04-2014, 11:23 AM
  3. Replies: 1
    Last Post: 04-23-2014, 09:15 PM
