Results 1 to 18 of 18
    Default File moving problem please help
    I can select a whole folder for a movie and move it to sd but once its in the sd storage it says cannot play file when all the files are clearly moved. If anyone encountered this problem please help
    Sent from my SM-G900T using AC Forums mobile app
  2. #2
    Default Re: File moving problem please help
    Did you check that you have the correct format by any chance ??
  3. #3
    Kelly Burby's Avatar
    Banned
    Posts
    Global Posts
    706 Global Posts
    Well, could you tell me one thing how are you able to move the movie to the SD card as far as I know S5 is coming with KitKat and in it the memory card is only in the readable mode not in the write mode ??? So ..... ??
  4. #4
    Quote Originally Posted by Kelly Burby View Post
    Not true, some applications would let you move them to the SD card while other wont. In any event i just moved bunch of pictures and videos to the SD card through the PC and moved other through the app itself.
  5. #5
    Banned
    Posts
    Global Posts
    706 Global Posts
    Quote Originally Posted by fantom305 View Post
    Which app you are using to do that, I would really be a help for me because on my device Its just not possible I can't move the pictures or songs in memory card in fact the data stored in the memory card is only in the read only mode.
  6. #6
    Use the stock app My Files to move file to/from device/SD card. It has read/write permissions.
  7. #7
    And if you root you can fix this Kit Kat sd card writing issue with a simple app from the market in a few seconds. (Link in another thread on this forum) But if your unrooted you have to use the stock "my files" which is a system app, to write and move files to sd card.
    Sent from my SM-G900P using Tapatalk
  8. #8
    Quote Originally Posted by mujertins View Post
    Plus, I don't know what video file your trying to play, but you might need a third party video app like "mx player" to play certain video files.
  9. #9
    If you are transfering video files from a Windows PC to your SD card on the phone, you should make sure it is connected as a media device. Then when you try to move video files, it will ask you if you want to just copy or "convert and copy". Convert and copy will convert a variety of file types to be able to play on your phone (I have tried with *.mov and *.wmv files, but I don't know all the file types that work).
  10. Thread Author  Thread Author    #10
    I apologize everybody I took very long to reply. The files I am downloading are just simple movie files that store in my gallery to play. I am using the my files app to transfer from device to sd and I make sure I move every file to sd just in case something is missing in order to play the file. My issue is once I download the file, it's playable but I don't want all that memory on my device so I store it to sd but once the files are moved(large files btw 1-3gb) using my files app the file will not play. I try to move it back to device and it still says cannot play video
  11. Thread Author  Thread Author    #11
    Everything is being downloaded from phone I'm not using a pc anything
  12. #12
    Could be the file was errored in transfer. Is the file still the same original size?
  13. Thread Author  Thread Author    #13
    Yes sir. It would stop transferring if it was errored I believe.
  14. Thread Author  Thread Author    #14
    I just tried a small file and it still did not work
  15. Thread Author  Thread Author    #15
    It may have to be mp4 file. The other files were. Ttt whatever that means
  16. #16
    Movie files have to be mp4, that is why atishc said that when you transfer from pc to sd card they should be converted and copied in order to play on your phone.
  17. Thread Author  Thread Author    #17
    I figured out it was an sd card issue just vidEos don't work
  18. #18
    Try using App manager III, in the google store. A lot easier moving files to SD card.
  1. Galixy S 3 water damage help?
    By urz223 in forum AT&T Galaxy S3
    Last Post: 04-26-2014, 01:42 AM
  2. Problem Updating
    By Chukklz9413 in forum HTC One M7
    Last Post: 04-25-2014, 08:47 AM
  3. HELP serious s4 problems
    By djdominator555 in forum Samsung Galaxy S4
    Last Post: 04-24-2014, 10:56 PM
  4. S Note & Evernote Login Problems
    By toastayy in forum Samsung Galaxy Note 8.0
    Last Post: 04-24-2014, 09:52 PM
  5. Backup Problems
    By kjh84 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 04-24-2014, 05:29 PM
