1. TomosTB's Avatar
    Hi there. I seem to be the only one who has noticed this, as I have searched everywhere online for an answer! If you hold the back cover of the S5 up to the light, there is a hidden circuit embedded in the plastic. This seems to induct power from the battery, which it sits next to, but what is it for? Is it something to do with s health, or is it a passport style tracking device?
    04-27-2014 07:43 AM
  2. dancing-bass's Avatar
    As a guess, this could be an antenna. Either for the wireless radios, NFC, Bluetooth, or that sort of thing. Can you post pics??
    04-27-2014 09:18 AM
  3. Micle Arons's Avatar
    There are two different Samsung Galaxy S5 back cover,the normal back cover and the wireless charging battery cover.
    The wireless charging battery cover:
    Utilizing the Qi global standard for inductive charging, you can charge the Galaxy S 5 phone without the need to plug in. Once the battery cover is installed, simply place your device directly onto the Samsung Wireless Charging Pad (sold separately) and your phone begins to charge .
    04-28-2014 06:22 AM
  4. TomosTB's Avatar
    Thanks very much. That's clever stuff
    04-28-2014 10:10 AM
  5. TomosTB's Avatar
    Dancing-bass - https://www.dropbox.com/s/mswxory11h...428_100808.jpg
    04-28-2014 10:11 AM
  6. dancing-bass's Avatar
    Sounds like Micle Arons nailed it. Thanks for the pic though, I was curious what exactly you were talking about. The pic seems to line up exactly with what a wireless charging setup would look like
    04-28-2014 10:19 AM
  7. geoffwhite18's Avatar
    I think it's nfc. I'm not sure how it works but the phone also knows when you remove the cover. The standard non charging cover definitely has a sensor of some type in there.
    04-28-2014 11:13 AM
  1. Replies: 1
    Last Post: 07-17-2014, 11:25 AM
  2. Galaxy S3 I9300: App wont let me log in - thinks I am outside UK
    By tiptap in forum Samsung Galaxy SIII I9300
    Last Post: 04-27-2014, 01:41 PM
  3. Samsung Galaxy Camera Photo app compatibility?
    By springerspaniel in forum General Help and How To
    Last Post: 04-27-2014, 11:44 AM
  4. Solo Launcher for Galaxy Note 3
    By clarkcant in forum Android 4.4 KitKat
    Last Post: 04-27-2014, 07:14 AM
