Results 1 to 18 of 18
Like Tree3Likes
  • 2 Post By jonebk12
  • 1 Post By ffejjj
  • 1 Post By Golfdriver97
    Default How to recover a frozen s5 without a battery pull ?
    So yesterday my s5 froze while I was using it. I was simultaneously using whatsapp and viber. The screen went unresponsive, (but no black screen). I waited for 2-3 minutes but it stayed frozen at that point. I use nova launcher.
    Long pressed power key, no response. Finally had to do a battery pull to reboot.
    Two questions.
    1. Has anyone experienced such freezes while using the phone? Should I be worried ? This is the first freeze I saw on this phone, and I have been using the phone for about 2 weeks now.
    2. Is there any hard key combination I can use to recover the phone ? I am coming from the Lumia 920 which had such a key combo. Removing the phone out of my Spigen Tough armor is an annoyance, albeit a minor one.
  2. #2
    sirmaru's Avatar
    Posts
    Global Posts
    265 Global Posts
    Default Re: How to recover a frozen s5 without a battery pull ?
    Long press on the power key and you can either do a full power shut down (usually that's enough) or a phone reset.
  3. #3
    Official manual says power button plus volume down simultaneously for at least 7 seconds.
  4. #4
    Me too. It was the Facebook app for me. Really embarrassing. It happen at a local sort of upper crust hangout and I’m sure everyone was watching me snap a pic of my drink and go to post it and the phone froze up. Same scenario though – Otterbox Defender case and I almost pulled it apart to pull the battery, but before I fully disassembled it a pop up reported that Facebook stopped responding or whatever and let me submit a report.
    I was holding down the power, trying the home button and power, everything I could think of and wondering the very same thing. The screen timed out a few times while I was trying, but nothing let me force a shutdown, reboot, etc.
  5. #5
    Quote Originally Posted by jonebk12 View Post
    Excellent to know! I was red faced over it.
    Thanks. So this will just force reboot the phone, without any kind of factory reset/data loss. Correct ?
    I thought days of Android randomly freezing are over. Guess not. Hopefully this was an isolated incident.
  7. #7
    Quote Originally Posted by ranpkri55 View Post
    It's less about android freezing and more about the specific device doing so. I've been freeze free for 2 years on 2 separate devices by the same manufacturer.
    Sent from my EVO using AC Forums mobile app
    Golfdriver97 likes this.
  8. #8
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    I'm inclined to agree with ffejjj. I have had the Moto X for almost a year, and only one freeze. My Nexus is about 6 months old and has yet to freeze.
    Sent from my HTC One_M8 using AC Forums mobile app
    ffejjj likes this.
  9. #9
    yes, very frustrating,
    held the volume down and power button, 7 secs it works, but its a bloody new phone
    why ?
  10. #10
    to hold the volume down button and power button for at least 7 seconds worked like a champ. Thanks for the tip.
  11. #11
    Smile Re: How to recover a frozen s5 without a battery pull ?
    After trying any number of random combinations of external buttons on my own, my Google search found your post with this response to another user's question about restarting a frozen screen on the Galaxy S5 -- and lo and behold, it's a winner.
    Many thanks on Christmas day for restoring my month old Samsung Galaxy S5 to full use.
    Coupledocs
  12. #12
    Thanks it worked as described.
  13. #13
    I can not tell you how much I appreciate this advice. Nothing else worked, then I saw your post. Quick and easy. You saved me from hours of frustration Thank You!
  14. #14
    Talking Re: How to recover a frozen s5 without a battery pull ?
    power and volume button worked a treat! thanks heaps
  15. #15
    holding volume down and power button works
    thanks i thought i did it but it took about 10 seconds
    thanks
  16. #16
    Power button plus volume down for 7 seconds did the trick. Thank you VERY much.
  17. #17
    The procedure of pressing the down volume and power button simultaneously for 10 to 20 sec worked for me, but only after I removed my S5 from it's otterbox case.
    I think that was because it was easier to press both buttons simultaneously without the case and it's rubber buttons. Otherwise one button or the other was getting pressed first.
  18. #18
    volume down and power button worked for my galaxy a3
  1. lag as bad as s5?
    By manni1to in forum Samsung Galaxy Note 3
    Last Post: 07-03-2014, 04:46 AM
  2. Screen shot of my Battery usage. Typical?
    By Jon Jackson in forum Samsung Galaxy S5
    Last Post: 05-01-2014, 12:28 PM
  3. Galaxy S5 AT&T Rooting/Bloat Ware Removal
    By diabsoule in forum Samsung Galaxy S5
    Last Post: 05-01-2014, 11:58 AM
  4. How to turn Music Player off and on?
    By mc4nam in forum LG G2
    Last Post: 04-30-2014, 01:11 PM
  5. Replies: 0
    Last Post: 04-30-2014, 01:05 PM
