Results 1 to 16 of 16
    Blahzee#AC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default What's wrong with my battery please help
    Here is today
    Here's a few days ago
    Sent from my SM-G900V using Tapatalk
  2. #2
    williams448's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: What's wrong with my battery please help
    Have you done a restart? I've also read where juice defender has major battery drain on the s5.
    Sent from my Nexus 7 using AC Forums mobile app
  3. #3
    Kwesi Yasay's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Try factory resetting it and observe using gsam. Just install a few apps.
    Sent from my HTC One_M8 using AC Forums mobile app
  4. #4
    Blahzee's Avatar
    Posts
    Global Posts
    271 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Kwesi Yasay View Post
    What do you mean by just install a few apps? Thanks guys. Is there any other reasons its draining a lot faster than 2 days ago? My wifi seems to be cutting in and out for a few seconds constantly. Does that have something to do and what causes the wifi to do that?
  5. #5
    sirmaru's Avatar
    Posts
    Global Posts
    265 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Turn Ultra Power Saving on when not running apps. You can still have phone calls and messaging active in that mode. I only have to charge my s5 once per week.
  6. #6
    Blahzee's Avatar
    Posts
    Global Posts
    271 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The thing is it started draining quickly like this yesterday and today I've had it since the 11th. I did nothing different and didn't install anything new but like I said my wifi has been acting funny by constantly disconnecting an reconnecting maybe thats what cause this massive draining. Will the wifi problem have this effect and how can I fix it?
  7. #7
    Blahzee's Avatar
    Posts
    Global Posts
    271 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by sirmaru View Post
    I'm constantly using apps
  8. #8
    sirmaru's Avatar
    Posts
    Global Posts
    265 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Blahzee View Post
    Then turn on Ultra Power Saving when you sleep. It could double your battery life.
  9. #9
    Blahzee's Avatar
    Posts
    Global Posts
    271 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I turn the phone off when I sleep.
  10. #10
    byeblackberry's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Probably the juice defender. Its 8:24 p.m. And I still have 60 percent battery. Its been unplugged since 7 a.m.
  11. #11
    Blahzee's Avatar
    Posts
    Global Posts
    271 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I turn the phone off when I sleep and also use battery doctor even thought im not sure if it helps but I like to believe so.
  12. #12
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You don't need anything to help with the battery on this phone. Best I've ever had.
  13. #13
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I mean dont install so many apps at a time. Just a few, the juice defender is useless now because new smartphones can really optimize the batt life. I suggest you install JD and install GSam to monitor the battery thoroughly. Maybe your location is set on high accuracy?
  14. Thread Author  Thread Author    #14
    Blahzee#AC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by byeblackberry View Post
    What was your screen on time
  15. Thread Author  Thread Author    #15
    Blahzee#AC's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Seriously you must not use it that often throughout the day mine is 62 percent right now and its been unplugged since 12:15 with 2 and a half hours of screen on. Tell me your secrets if im wrong
  16. #16
    Lynx's Avatar
    Posts
    Global Posts
    1,225 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This was mine from a few days ago, phone was off the charger at 7:15am. Ridiculously bad. I think I have a bad phone. Going back to Verizon shortly to swap it out I think.
    Tapin and Talkin on my Gold iPhone 5s
  1. Please Help! Won't boot
    By Eric Schall in forum AT&T Samsung Galaxy Note 3
    Last Post: 05-01-2014, 10:31 PM
  2. Replies: 8
    Last Post: 05-01-2014, 10:12 AM
  3. what launcher can I use to make the S5 feel like the 5S?
    By CarrierPigeon in forum Samsung Galaxy S5
    Last Post: 05-01-2014, 01:50 AM
  4. Replies: 0
    Last Post: 04-30-2014, 07:04 PM
  5. Begging for a Guru's help
    By Jennifer Perkins in forum AT&T Samsung Galaxy Note 3
    Last Post: 04-30-2014, 06:51 PM
