1. Ralelen's Avatar
    Having a weird issue where "Phone" is using %53 of my battery power. I tried a reset but it is still happening. Is this common? Has anyone else experienced this?
    05-01-2014 10:49 AM
  2. Jon Jackson's Avatar
    Are you using your phone as a phone?
    05-01-2014 10:55 AM
  3. Ralelen's Avatar
    Not quite sure what you mean. I haven't made a call since yesterday. I went to bed with %80 battery remaining, and woke up with the battery drained. Checked the power settings and "PHONE" was using % 53 of the power. Did a restart and it's still using % 53.
    05-01-2014 11:03 AM
  4. sirmaru's Avatar
    When you go to sleep, use TWO fingers to swipe down from the top and click to turn on Ultra Power Savings Mode. You will then lose at most 2% overnight and probably only 1%.
    05-01-2014 11:16 AM
  5. Ralelen's Avatar
    Thanks for the reply, but I'm looking for a reason for this power usage.
    05-01-2014 11:29 AM
  6. L0n3N1nja's Avatar
    Restarting the phone won't change the battery used percentage amounts, you need to fully charge the phone for those to reset.
    It's likely your phone app messed up and kept running in the background, restarting probably fixed it but you won't know until you are on another charge cycle.
    05-01-2014 12:45 PM
  7. mujertins's Avatar
    Yea let the battery die as well it's always good to train the battery
    Sent from my SM-G900T using AC Forums mobile app
    05-01-2014 01:00 PM
  8. Ralelen's Avatar
    Thanks. This worked.
    05-01-2014 04:17 PM
  1. Use Bluetooth Headset for "Speech to Text"?
    By Jon44 in forum Samsung Galaxy S5
    Last Post: 09-28-2014, 10:17 PM
  2. 14 hours and 73% Battery remaing on Galaxy Note 3
    By waz ahmer in forum Samsung Galaxy Note 3
    Last Post: 07-02-2014, 02:28 PM
  3. is net neutrality a good or bad thing for the openness of the internet?
    By ahawkua in forum General News & Discussion
    Last Post: 05-05-2014, 12:57 PM
  4. Battery life has been cut in half on my Note 2
    By 1812dave in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-01-2014, 12:13 PM
  5. Replies: 0
    Last Post: 05-01-2014, 10:46 AM
