1. LisaLee660's Avatar
    I guess there was a recent FB Android update and now I only see "recent" posts every so often. My "Most Recent" feed never shows the number of new recent posts. Pretty annoying. Yes, I have uninstalled and re-installed FB.
    Is anyone else having this problem?
    05-01-2014 07:11 PM
  2. erasat's Avatar
    Yes, everybody have the same "problem", that's what it is after latest update. The only way to see it now is going to the same menu you see in the picture you attached and there you will find your Most Recent option. Problem is that's not a final solution as it defaults back every time.
    LisaLee660 and Aquila like this.
    05-01-2014 07:17 PM
  3. keyzlife's Avatar
    Yes it's been well discussed on the forums. I'm in the testers group so I've been dealing with it for a while. It's really frustrating. You can always use the browser until the update hits. Hopefully a fix is near!
    sent from my T-Mobile Galaxy Note 3 using Tapatalk
    LisaLee660 likes this.
    05-01-2014 07:17 PM
  4. LisaLee660's Avatar
    Thanks. I do keep gong back to that menu, but when I click on recent it hardly ever shows me actual recent posts. There's never a number of posts highlighted in blue posts like every other category, but when I check it on my Macbook it's fine. Oh well. Thanks for your response.
    05-01-2014 07:28 PM
  5. the block's Avatar
    Don't worry, Facebook knows better than you do about what you want to see in your own feed
    The best workaround to it is making Most Recent your only favorite, so it is at the top and easy to get to and select when you go to the More tab.
    05-01-2014 07:56 PM
  6. fofjjsr's Avatar
    So I was really frustrated with this update, because I was missing posts from family and friends because Facebook was deciding what was important all the sudden, and would not let me sort my own main feed anymore. So, I went to update my review and it told me I couldn't because I was using a beta version (odd). Then noticed there are literally no reviews after the latest update (odd again). I didn't sign up for a beta version of Facebook anything, and this was a standard Facebook update I thought....
    05-02-2014 12:12 AM
  7. jphillips1963's Avatar
    If Facebook downsize and quit with all there phishing on web browsing and trying to guess what people we may know and all the other garbage they throw at us for advertising we wouldn't have these issues
    Sent from my Droid RAZR Maxx HD using Tapatalk Pro
    05-02-2014 12:41 AM
  1. Samsung S3 Screen problem (unique)
    By ttvh06 in forum Samsung Galaxy S3
    Last Post: 10-30-2015, 05:23 PM
  2. Copying files problem
    By quarrymanpaul in forum HTC One M8
    Last Post: 05-02-2014, 12:23 PM
  3. Issue with changing a contact on the Moto X
    By manhattan123 in forum Moto X (2013)
    Last Post: 05-01-2014, 05:01 PM
  4. Uploading photos to Facebook
    By Gregor Drnovsek in forum Samsung Galaxy S5
    Last Post: 05-01-2014, 04:17 PM
