Results 1 to 4 of 4
    shanezam203's Avatar
    Posts
    Global Posts
    180 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Any way to Multi View Spotify & Scout or GPS Navigation?
    I use my s5 for GPS driving directions & Spotify while I drive; are there ways to enable Multi Viewing and see directions and Spotify at the same time?
    I have Widgets for Spotify and one for Scout, but when I open either app it is full screen and I have to push bottom left to see open running apps to toggle between the two, any way to view them side by side?
  2. #2
    BadgerVadge907's Avatar
    Posts
    Global Posts
    48 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Any way to Multi View Spotify & Scout or GPS Navigation?
    If you have root access you can download the floating windows app. I can watch 2 videos and 2 windows at the same time, and its transparent. doesnt the S5 have the multi task option?
    Posts
    Global Posts
    180 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't see the ability to add Spotify or Scout, only hangouts, facebook, maps... and a few others.
    Any suggestions how to split view Spotify and Scout for GPS?
  4. #4
    Seedlord's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by shanezam203 View Post
    Yea google /how-to/use-any-app-you-want-multi-window-view-your-samsung-galaxy-note-3-0150765/
    Its a how-to for galaxy Note 3 but it also works for galaxy s5
    You will need MW Manager
    I tested it works
  1. should I factory reset or return or nah?
    By thepurpleturtle in forum HTC One M8
    Last Post: 05-09-2014, 12:39 AM
  2. Replies: 5
    Last Post: 05-06-2014, 08:58 PM
  3. If I buy an M8 from HTC, do I get to return it?
    By blackdogAC in forum HTC One M8
    Last Post: 05-05-2014, 08:51 PM
  4. Replies: 0
    Last Post: 05-05-2014, 01:44 PM
