Results 1 to 10 of 10
    Default Battery usage seems a little iffy
    What's "Android system" anyway?
    Is just 13 hours of this kind of usage normal?
    Sent from my SM-G900V using AC Forums mobile app
    Attached Thumbnails Attached Thumbnails Battery usage seems a little iffy-1399337216285.jpg   Battery usage seems a little iffy-1399337235607.jpg
  2. Thread Author  Thread Author    #2
    Default Re: Battery usage seems a little iffy
    Does anyone know if the phone keeps searching for a 4G connection even when you're signed on to a wifi network? I'm wondering if this is the case if it might be a good idea to disable data while you're in wifi.
    Any thoughts?
  3. #3
    i always disable wifi and 4g when i'm not using the phone. otherwise, it's gonna search for signal everytime the phone is on, which will cause battery drain.
    Can someone explain why "Android System" is killing my battery life?
  5. #5
    Default
    Quote Originally Posted by PsychDoc View Post
    Do you have location reporting on? What apps are syncing with your Google account? I don't have an S5 but shuttling off reporting and unchecking everything other than Gmail cut "Android System" for both my Moto X and M8 to under 10%. Disabling any carrier bloat too always helps.
    Posted from HTC One M8 via Android Central App
  6. #6
    Any thoughts?
    Quote Originally Posted by PainFX View Post
    It only drains your battery if in a weak signal area. The phone will keep the connection to the towers but use your wifi.. Then jump to 4g once off wifi.
    Sent from my T-Mobile Note 3 using AC Forums.
  7. #7
    sirmaru's Avatar
    Posts
    Global Posts
    265 Global Posts
    If one turns on Ultra Power Savings when the phone is not in use, then it could last up to a full week without a recharge.
  8. #8
    Have you tried buying an m8?
  9. #9
    Quote Originally Posted by thepurpleturtle View Post
    Dude.....lol......you're terrible.
    Disable your animations, uninstall any app killers and disable location when not using the phone. Also you can use Ultra Power Saving mode if you're really needing a phone that will keep a charge for a week or more.
  10. #10
    I forgot to take a screen shot. Under moderate use some gaming, i had like 20 hours on battery. was down to 5% at 20 hours
  1. Best battery app?
    By PainFX in forum Samsung Galaxy S5
    Last Post: 05-05-2014, 09:10 PM
  2. Battery heating up?
    By psychspirit in forum Samsung Galaxy S5
    Last Post: 05-05-2014, 05:57 PM
  3. Samsung Galaxy S3 battery problem
    By Phil_SCS in forum General Help and How To
    Last Post: 05-05-2014, 04:14 PM
  4. ext battery charger
    By viper31573 in forum Verizon Galaxy Note 2
    Last Post: 05-05-2014, 03:37 PM
  5. Wifi usage when I have wifi off?
    By WhiteiPadMini in forum Samsung Galaxy S5
    Last Post: 05-05-2014, 01:40 PM
