1. ep70's Avatar
    Hi everyone...I am new to the Samsung S family and Android.. Coming from a long line of Blackberry , I am learning something new everyday lol.. I recently purchased the Samsung S5 , and so far I am very happy with it , and still learning everything this thing can do lol. My question is , it seems that my battery is running low rather quickly towards the end of the day . And especially after an updated last week , it seems to be running at 14% by end of day. I am running in the Power Saving mode , but is there something running in the background that I don't know about that may be putting a drain on the battery? I keep all apps closed out when I am not using them. Any thoughts ? And thank you for any advice you may have
    05-07-2014 09:19 AM
  2. mattskr's Avatar
    When your battery is low, check "Settings -> Battery" and see which apps or services are consuming the most of your battery.
    05-07-2014 09:23 AM
  3. bassplayrguy's Avatar
    stop closing out apps when not in use. this does not help, but hurt battery life. Android will close and make ram available as needed. These apps are not running in the background, rather put into closer storage for quicker opening, thus saving battery life. Can you post a screen shot of your battery usage page?
    WhiteiPadMini likes this.
    05-07-2014 09:27 AM
  4. PsychDoc's Avatar
    Is this normal battery useage? What is "Android System" and why is it consuming so much of my battery?Battery Question??-2014-05-06-00.44.25.jpgBattery Question??-2014-05-06-00.44.35.jpgClick image for larger version.
Name:	2014-05-06 00.44.25.jpg
    05-07-2014 09:38 AM
  5. ep70's Avatar
    AAhhhhh ok , I will leave the apps open .. I was always closing and opening them .. I'll see how it runs today. Unfortunately I can't post the screen shot because I am on my work computer lol. Thanks for the advice again guys..Psychdoc , my screen looks similar to your batt usage..
    05-07-2014 11:35 AM
  6. Jon Jackson's Avatar
    What Pycho said is spot on, also as a wonderful benefit, this will prevent any lag(s) from happening.
    bassplayrguy likes this.
    05-07-2014 11:37 AM
  7. PsychDoc's Avatar
    I don't think I "said" anything other than to post screen shots of my battery useage and inquire as to whether this was normal or not. What else did you take from my post?
    05-07-2014 12:51 PM
  8. Jon Jackson's Avatar
    My apologies. I meant Bassplayer.
    05-07-2014 01:05 PM
  1. Replies: 82
    Last Post: 08-09-2014, 06:07 AM
  2. New OEM batteries on ebay, real or not?
    By 3rdpig in forum Samsung Galaxy S5 Accessories
    Last Post: 07-08-2014, 12:39 AM
  3. File Moving Question
    By navallint in forum The Android Central Lounge
    Last Post: 05-08-2014, 03:54 AM
  4. Loose battery cover
    By Eclipse2K in forum Samsung Galaxy S5
    Last Post: 05-07-2014, 11:33 PM
  5. Snapdragon Battery Guru ??
    By Jalopiejoe in forum Samsung Galaxy Note 3
    Last Post: 05-06-2014, 10:00 PM
