05-09-2014 03:08 PM
38 12
tools
  1. Lynx's Avatar
    This doesn't make sense, I didn't use my phone until recently and boom my battery was drained. Any ideas?
    Sent from my SM-G900V using Tapatalk
    05-07-2014 02:58 PM
  2. Jon Jackson's Avatar
    Are you using any anti virus, lookout, app killers, ram cleaners etc?
    05-07-2014 02:59 PM
  3. Lynx's Avatar
    Nope.
    05-07-2014 03:01 PM
  4. Jon Jackson's Avatar
    Live wall paper? Batteries have their good days and bad for sure....it does seem like every Android phone I have had has taken a few weeks to "adjust" or whatever. I unplugged mine yesterday at 7am and at 7pm it was 75% or so.....I've had it off charger today for 8 hours and it's at 65% but I am running a live wall paper today, have no idea if that's draining that much more. Probably is.
    05-07-2014 03:03 PM
  5. Lynx's Avatar
    I am running Nova Launcher, no live wallpaper or anything. I am in a place with good reception also so not sure what is going on but thats insanely awful battery.
    05-07-2014 03:14 PM
  6. Jon Jackson's Avatar
    I agree....how long have you had the phone? Has it been like this the entire time? Also I notice there's a lot of icons on the left side of your phone showing...what apps are those?
    05-07-2014 03:17 PM
  7. Jon Jackson's Avatar
    for comparison....
    05-07-2014 03:20 PM
  8. Lynx's Avatar
    The icons on the top left are tasker, wifi being found, a missed call, and showing my phone is connected to the Gear 2 Neo.
    No it hasnt been this bad, its never been great but not this awful lol.
    05-07-2014 03:27 PM
  9. Jon Jackson's Avatar
    Did it maybe update a bunch of apps or something? Wish I could be more helpful. I mean...it's gotta be something ya know. Yesterday I had a GREAT battery day. Today meh....lol....All in all though, it's an all day battery - which is the first for me.
    05-07-2014 03:31 PM
  10. WhiteiPadMini's Avatar
    You may have a defective Battery. Have you run the battery down until the device turns it self off to calibrate the accurate reading of the battery? If it still does it, then there is something wrong with the battery and you may need to get the battery replaced.
    05-07-2014 03:38 PM
  11. sirmaru's Avatar
    When you don't use the phone like at night when sleeping, use TWO fingers to swipe down and then tap UPS. Battery performance will soar and almost no juice will be used while you are away from your phone.
    So far I've gotten SIX days on the first cycle with 4:47 screen time and 21:44 battery time and then FOUR day with 3:20 screen time and 19:37 battery time.
    05-07-2014 03:51 PM
  12. Lynx's Avatar
    So I just went into gsam battery and that said the screen was on way longer. Here is the screen shot from that.
    05-07-2014 03:52 PM
  13. Lynx's Avatar
    I charge my phone at night so that's not a big deal.
    WhiteiPadMini likes this.
    05-07-2014 04:38 PM
  14. Jon Jackson's Avatar
    Exactly, it's an all day battery and that's the bottom line. BUT, you and I both are curious why all of a sudden one day, our battery life is bad. Yesterday I got to work and I was at 99%, it's a 30 minute drive. Today I got to work and 91%. *Shrugs*
    05-07-2014 04:41 PM
  15. Seeker4's Avatar
    Biggest drain on my phone is GPS, which I use both for tracking auto use and for tracking hiking. If some app using the GPS seemingly gets stuck running, the battery will last less than a day. If not using the GPS, it will last about 3 days in my use. When I see that happening (and confirm with a very steep discharge curve in GSam), I just reboot the phone and seems to take it back to normal. Long phone calls (using T-Mobile wi-fi calling) also drains the battery rapidly, probably more quickly than GPS but I use GPS more than wi-fi calling.
    I generally charge the battery every second day, sooner sometimes. I'm waiting for Samsung to release the wireless charging back to make recharging easier.
    05-07-2014 07:24 PM
  16. Lynx's Avatar
    Holy crap I definitely have to recharge my phone nightly which is fine. The problem is I hadnt touched my phone at all today until lunch and checked and it was at 60%. I literally unplugged it at 100% from my commute to work, walked in, set it down, and drained to 60% by lunch. Thats awful. I switched to ART last night and I wonder if that may have something to do with it....
    05-07-2014 08:10 PM
  17. Seeker4's Avatar
    You might want to check Google Location Reporting and see if it is off. Location reporting can use both GPS resources and data resources to keep updating your location in Google's records.
    05-07-2014 08:41 PM
  18. Relgoshan's Avatar
    That can contribute, yes. Most people claim better battery under ART but sometimes an app will behave strangely and you'll need to clear your cache.
    But that Android System. When my phone is running right that goes less than 5% of system power drain.
    05-07-2014 08:41 PM
  19. Lynx's Avatar
    I have google location reporting off. I am going to see what happens the next few days. I really want the Verizon version to be rooted so I can mess with it...
    05-07-2014 08:44 PM
  20. icouldntpossiblycomment's Avatar
    Are you often in an area that has poor reception? If the signal is weak, the phone will be searching for a signal all the time and I find that can really drain the battery fast.
    05-07-2014 09:01 PM
  21. Lynx's Avatar
    No I even mentioned I had great reception all day.
    05-08-2014 12:55 PM
  22. Jon Jackson's Avatar
    You shouldn't have be seeing battery problems with this phone....
    05-08-2014 12:56 PM
  23. Jon Jackson's Avatar
    After a 10 hour day (work plus travel time) I should still be in the 90's when I get home and in the 80's when I got to bed. Might not even charge my phone until tomorrow night.
    05-08-2014 12:57 PM
  24. ickymini's Avatar
    maybe turning off apps that you don't use so that it won't run in the background. that also helps!
    05-08-2014 01:11 PM
  25. Jon Jackson's Avatar
    I've found that keeping all apps open, not clearing cache or ram helps the battery more so.
    05-08-2014 01:13 PM
38 12
  1. Is Note 3 worthwhile upgrade from Note 2?
    By Lefty Drummer in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-15-2014, 10:43 PM
  2. SHOCK: Battery drain 400% worse LTE (I found out why!)
    By pcguys in forum Samsung Galaxy Note 3
    Last Post: 05-09-2014, 02:42 PM
  3. Gaming on the 2013 vs 2012?
    By Jason Daniels2 in forum Google Nexus 7 Tablet (2013)
    Last Post: 05-08-2014, 11:47 AM
  4. My phone welded the charger :- /
    By dennador in forum Samsung Galaxy S II Skyrocket
    Last Post: 05-07-2014, 11:15 PM
  5. updated for what today?
    By ltfm in forum Samsung Galaxy S II
    Last Post: 05-07-2014, 02:44 PM
