1. Surend ran's Avatar
    Hi All,
    I am looking at forums and on the internet, its everywhere now.
    S5 is having problems with connecting to Wifi? I bought S5 a week ago. Till today morning I dont have any problems in connecting to different Wifi networks.
    All of a sudden, Wifi at my work not connecting to internet
    I tried disconnect and reconnect
    1.Rebooted twice
    2.Airplane mode on and off
    3.I saw that changing connect IP from DHCP to static might work, but unfortunately I dont see the connect button enabled when I change from DHCP to Static, So this one never works for me.
    4.Forget and connect to Wifi also not works
    Why this sudden problem where I found earlier today Wifi was just fine at my home.
    Any help would be much appreciated
    Thanks
    Suren
    05-08-2014 02:33 AM
  2. Russ556's Avatar
    I am having pretty much the same issue. I got the phone during the weekend and it worked great on my wifi at home.
    Today I go into work and I could connect to the wifi but it would drop out within a minute of each use. I would stay connected but my internet and music would stop working.
    I switched from an iPhone 4 which had no problems at all anywhere in my work place (i work in a school). Also, I work with someone who has an S4 and someone who has an S3 and neither of them had any problems with their wifi connections today.
    If I don't solve this issue within a week I will be returning my phone. I don't want to have to pay for extra data when I know I'm in wifi coverage.
    05-12-2014 10:55 PM
  3. winnersmw's Avatar
    I'm having this issue as well. After a few minutes of being on wifi, I won't be able to transfer data even though I'm still connected to the network. Just another of the many issues I'm having with this phone.
    05-19-2014 12:34 AM
  4. Almeuit's Avatar
    Check this setting... Go to wifi... Hit your menu button and go to advanced and then disable this option.
    Sent from my T-Mobile Note 3 using AC Forums.
    Attached Thumbnails Wifi issue at Work or public?-1400507378323.jpg   Wifi issue at Work or public?-1400507388444.jpg
    05-19-2014 08:49 AM
  5. winnersmw's Avatar
    Yeah I already have that disabled. Also, the problem isn't that the device is switching from wifi to mobile data (as per that setting), but rather that no data can be transferred over wifi.
    05-19-2014 02:47 PM
  1. Why isn't MMS working on S5 when on WiFi?
    By cliffy223 in forum Samsung Galaxy S5
    Last Post: 08-28-2016, 12:36 AM
  2. Replies: 6
    Last Post: 03-30-2016, 02:14 PM
  3. Viber touch screen not working
    By Gary Pickering1 in forum Samsung Galaxy Note 3
    Last Post: 08-27-2014, 02:42 AM
  4. LG Stock Backup Not Working
    By jeffreynothing43 in forum Sprint LG G2
    Last Post: 05-18-2014, 04:41 PM
