1. kilofoxtrot's Avatar
    I have installed/uninstalled a ton of apps including launchers. I have noticed a slight hesitation when interacting with the phone. Its not a snappy as when I first got it. (notice I did not use the "L" word ). FYI... I did modify the animation settings during this time period.
    Do you think it would help things if I did a factory reset to smooth things out?
    05-12-2014 09:06 AM
  2. Golfdriver97's Avatar
    Probably a clearing of the cache in recovery might help just as well as a reset. Try this: [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
    Follow instructions for the S3, and clear the cache partition.
    05-12-2014 09:10 AM
  3. bassplayrguy's Avatar
    What does clearing the cache do? Is it something that should be done on a regular basis?
    05-12-2014 09:14 AM
  4. Golfdriver97's Avatar
    Sometimes the system cache can bog down the OS from properly functioning. Either the data is old and Android has to spend more time 'finding' what it is looking for or the data gets corrupted, clearing it gives Android a refresh.
    Cache clears often help with keeping a device snappy, and really only need to be done on an as needed basis, or whenever the OS gets updated. I typically do this once a month on all my devices. I have one specific day a month where I go through everything; my PC, Android devices, etc, and do cache clears, and software PC cleaning. Just a habit I am in. Come to think of it, I am due for this tomorrow...lol
    05-12-2014 09:28 AM
  5. bassplayrguy's Avatar
    But this does not delete any useful info right?
    05-12-2014 10:05 AM
  6. Golfdriver97's Avatar
    No
    From an SOKP Nexus 5
    05-12-2014 10:06 AM
  7. sirmaru's Avatar
    Is there a difference between using the Reset option after holding down the power key for 30 seconds and the Reset option under the icon, Backup and Reset?
    05-12-2014 10:07 AM
  8. mnuttall87's Avatar
    If you jump into Developer options, you could also switch from Dalvik to ART and then back...it forces every single app left on your phone to optimize. It'll take a good 15 minutes.
    05-12-2014 10:38 AM
  1. How can i connect my Tab 3 7 inch to my TV
    By shaydes in forum Samsung Galaxy Tab 7-inch
    Last Post: 03-16-2015, 11:04 AM
  2. I need help big time please.
    By Phill Evans in forum Google Nexus 7 Tablet (2012)
    Last Post: 05-15-2014, 12:20 PM
  3. The os of my lg nexus 4 is deleted...
    By syedfahad in forum Google Nexus 4
    Last Post: 05-12-2014, 08:48 AM
  4. Odd issue after shutting phone off
    By callihan_44 in forum HTC One M8
    Last Post: 05-12-2014, 08:43 AM
  5. Pls. HELP..: Sim card not recognised / baseband version & IMEI shows "Unknown"
    By Emil Baby George in forum T-Mobile Samsung Galaxy S4
    Last Post: 05-12-2014, 05:45 AM
