Samsung Link Platform draining battery
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
Anyone know what this is? It's killing my battery! It started shooting up after Group Play updated and I don't even use it
Sent from my Galaxy S5 using Tapatalk
Go to settings---->application---> select the app then clear cache and force close it
Press THANK YOU and LIKE button if you gets the answer
i downloaded the update too and noticed a huge battery drain, i have since uninstalled this app and order has been restored.
:D
Samsung Link...if you are rooted, use system app remover to delete it
Sent from my HTC One using Tapatalk
Reading through this thread I have to say I begin to understand why people flock to iphones. I HATE the Apple universe but there is something to be said about everything just working perfectly right out of the box. In the Samsung/Android universe it seems like we're always having to dodge shrapnel (LOL). While I think the payoff in fredom and flexibility is well worth it, I can really see how people who couldn't care less about technology in its own right would just love to kick back in the well-padded Apple coccoon.
I solved the problem... I just turned it off... I never use it anyways
I used to have an iPhone... Even with the few problems I have had, I will never go back to IPhone... This is eons better
Any idea what it does? I turned it off too but I'd like to know what it might screw with. I assume it's just app update crap.
Its an app called Samsung Link...it allows you to connect the phone to a Samsung TV or other Samsung device and stream media...I don't need it,
Alexcarter
