1. m3ta1he4d666's Avatar
    Hi guys! Which one do you prefer for your S5? Light Flow or LEDBlinker? Thanks!
    05-14-2014 12:24 AM
  2. Greg C's Avatar
    I prefer Light Flow because of the customizations you can do with it...such as which apps use the notification, sound, colors, speed of the blinking and etc.
    05-14-2014 01:05 AM
  3. m3ta1he4d666's Avatar
    Thanks mate. Have tried and both is good. Currently using Light Flow.
    05-14-2014 07:40 PM
  4. MOST2K2's Avatar
    Hi, i am the developer of LEDBlinker and i wanted to give you some good points for my app
    * No root required, too
    * ALL apps are supported (hit + button to add your own apps)
    * on Screen led is supported for phones like s3 mini, s4 mini
    * compatibility rate is the same or even better for my app
    * simple user Interface (you can hide not used apps and add apps on your own)
    * less battery draining than other apps (some users wrote that in the Ratings)
    Let me know what you think!
    keoommen likes this.
    06-29-2014 07:35 AM
  5. Almeuit's Avatar
    I use Light Flow and love it.
    Sent from my T-Mobile Note 3 using AC Forums.
    06-29-2014 08:12 AM
  6. Mojave's Avatar
    I'm using Light Flow and it works great for me. I have also tried Light Manager but had issues with it. In all fairness I have not yet tired LED Blinker.
    06-29-2014 08:13 AM
  7. MOST2K2's Avatar
    then give it a try
    isdaako likes this.
    06-29-2014 08:39 AM
  8. Greg C's Avatar
    Light Flow all the way... especially after the latest update.
    Sent from my Samsung Galaxy S5
    06-29-2014 04:12 PM
  9. MOST2K2's Avatar
    but my app has a lot of Advantages see my post above.
    and in the future i will add a new ui, too
    06-29-2014 11:54 PM
  10. isdaako's Avatar
    Don't forget that LED Blinker is $.12 cheaper than Light Flow.
    So, more than a dime less and very good customer support. LED Blinker for me.
    MOST2K2 likes this.
    06-30-2014 07:01 AM
  11. MOST2K2's Avatar
    Thank you, i do my very best
    06-30-2014 07:06 AM
  12. MOST2K2's Avatar
    A new Version was released last week and i got a cool Review.
    * totally new user interface
    * light and dark color scheme
    * export/import settings
    * support for Threema group notifications
    * debug-mode for better error analysis
    * extra big LED added (on screen LED)
    * search function for adding new apps
    * new widget to deactivate LED Blinker/remove notifications quickly
    * Take a look at my other apps https://play.google.com/store/apps/d...=Mario+Ostwald
    LED Blinker Notifications app sheds light on your notifications - Android Community
    09-04-2014 12:49 AM
  13. MOST2K2's Avatar
    Searching for beta testers for cool new functions
    https://play.google.com/store/apps/d...com.ledblinker
    05-16-2015 04:28 AM
  1. HTC one m8 vs Samsung galaxy s5: battery life
    By thepurpleturtle in forum Phone Wars
    Last Post: 05-19-2014, 08:49 AM
  2. How to toggle on led light using volume buttons
    By jwalker007 in forum HTC One M8
    Last Post: 05-14-2014, 09:57 AM
  3. Network vs Wi-Fi
    By Mst99 in forum General Help and How To
    Last Post: 05-14-2014, 02:35 AM
