Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By PsychDoc
    monicakm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery Drain/Android OS
    OK, for the first week of ownership, my Android OS percentage under "Battery" hovered around 12%. Today, I look and it's at the top of the page with 40% :o Whaaaaaat? I made one change yesterday afternoon. I changed the screen time-out to 10 minutes instead of one or two. But only used the longer screen on time for a couple of hours. I've been turning it off when not needed but it's still set to 10 minutes. The screen percentage shows 19%. I'm at 32% battery charge after 1 day, 8 hrs and 10 mins.
  2. #2
    Jaycemiskel's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery Drain/Android OS
    If you've gone that long without a charge, your phone is doing just fine on battery life. I wouldn't worry about the numbers or percentages unless you aren't getting good battery life.
    Sent from my XPS 12-9Q33 using Tapatalk
  3. #3
    bassplayrguy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You are still at 32% after over 30 hours and your are concerned? What is it that you are expecting out of your battery?
  4. #4
    PsychDoc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by monicakm View Post
    You are kidding, right? 32 hours of use and you're still at 32%????
    And this is seen as a problem???
  5. #5
    Jon Jackson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by PsychDoc View Post
    You are kidding, right? 20 hours of use and you're still at 32%????
    Actually this would be 32 hours 10 minutes.
  6. #6
    PsychDoc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Jon Jackson View Post
    Fixed. Thanks.
    Jon Jackson likes this.
  7. #7
    Relgoshan's Avatar
    Posts
    Global Posts
    1,062 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The less you use your screen, the lower its percentage goes and the higher background tasks like System will go. But you should keep an eye whether app data is being synced or the phone is being kept half awake with the screen off. On my G Flex I usually can make at lesst two full days, with Android OS/Screen/Opera each using around 20%+ of the battery drain over that time. Android System is the one to watch out for, when working normally it seems to go 4-10% usage. When something is stuck like the camera staying powered, this number can shoot over 50% and wipe out your battery long before the day ends...
  8. Thread Author  Thread Author    #8
    monicakm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Relgoshan View Post
    Oh sorry! My bad. I thought it was the Android OS that people were complaining about in a recent thread (being so high). Just checked, and the Android SYSTEM is at 12%
    monicakm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by bassplayrguy View Post
    I didn't complain about my battery life. My post was concerning the Android OS usage. I simply posted the up time as a part of the equation. In a recent thread, some people were concerned about the high percentage of their Android System. I thought I remembered it being the Android OS.
  10. #10
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah, but our point was, it doesn't matter how high the usage percentage is if you're getting that long of battery life.
  11. #11
    Relgoshan's Avatar
    Posts
    Global Posts
    1,062 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That is within acceptable range for going two work days on one charge.
    Yeah, easy thing to mix up and it doesn't hurt to ask. Keep an eye on it tho. In my last run on battery I started around 66% on my Flex and got 6-1/2 hours of screen time with above 15% left over (??). Opera had three hours of CPU and 30% battery load, Screen had 27% load and Android OS had 18%....I see almost 11 hours of keep awake time, so I'll be running a wakelock detector to see if I can disable something to bring that down a little more. I'm not as obsessed as some about wakelocks and such, but saving 10% battery per day is worth it to reach four days off the mains reliably.
  1. How does Android determine how to open a file?
    By pollensa1946 in forum General Help and How To
    Last Post: 03-30-2015, 06:30 PM
  2. Android free games!
    By Daniel4ever in forum Tablet Apps
    Last Post: 01-02-2015, 05:37 PM
  3. Replies: 4
    Last Post: 06-10-2014, 03:26 AM
  4. Replies: 1
    Last Post: 05-16-2014, 08:46 AM
  5. IK Multimedia / iRig for android for audio recording
    By deezle250 in forum Droid RAZR MAXX
    Last Post: 05-14-2014, 10:09 AM
