Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By monicajae
    monicajae's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default battery compatibility
    I have the opportunity to acquire a couple of 4300mAh batteries but are for the I9600. Are they compatible with any galaxy s device? Of course specifically the s5? Thanks in advance.
  2. #2
    bassplayrguy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: battery compatibility
    Quote Originally Posted by monicajae View Post
    If it isn't made for it, don't use it.
    monicajae's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by bassplayrguy View Post
    Thanks
    bassplayrguy likes this.
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    13,762 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    The battery is likely different physically (size) and won't work with prior 'S' devices - I have not compared the S5 battery with other devices, so can't say for sure. As mentioned above, don't use it if it wasn't meant for your device. Also, be cautious when purchasing battery replacements that are dirt cheap. Last thing you want is a phone with hardware damage because a $2.00 battery purchased online caused problems.
  5. #5
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by srkmagnus View Post
    This exactly. I only buy Samsung batteries for my Samsung phones. It is too expensive to take the chance on a cheap battery overheating my device or blowing up inside my phone. 650 for a phone, it's worth 30 for a battery.
  1. Wonky battery "life"
    By triscuit22 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-10-2014, 12:49 PM
  2. Terrible battery life on the Verizon Samsung Galaxy S4
    By ickycoolboy1 in forum General Help and How To
    Last Post: 06-02-2014, 12:35 AM
  3. Headset compatible with moto G
    By aljoanto in forum Moto G (2013)
    Last Post: 05-17-2014, 06:21 AM
  4. What are the best browsers that are light on battery usage?
    By pantlesspenguin in forum General News & Discussion
    Last Post: 05-14-2014, 12:36 PM
  5. Battery Drain/Android OS
    By monicakm in forum Samsung Galaxy S5
    Last Post: 05-14-2014, 11:56 AM
