1. Limbo13's Avatar
    Hi guys,
    Hope u can help!
    Got an S5 4g LTE recently (switched from another Samsung android, kept my same phone number and 3g sim), but my instant notifications from whatsapp have been hit & miss! Sometimes i get the instant notifications ok, sometimes i don't!
    I have tried "everything" suggested on the www e.g. restart, uninstall, reinstall etc. I've checked the notification settings etc, i have it on "always show pop up". I have the "show notifications" on in the whatsapp bit after i enter the general phone settings.
    Too often i have to go into the app to find out if i have any messages.........which i sometimes do, and they were sent hours ago! i have been testing my S5 by sending myself messages using another phone, and it is hit or miss!
    Everything else is working aok, unit is (too) legit (to quit) Is it just my network provider?!
    Many thanks
    05-16-2014 10:09 AM
  2. Steve West's Avatar
    Sorry I do not have a solution.
    I am having the same problem, I am on EE. I can not see a solution out there yet.
    Silly question but have you updated the phone and re booted it? Mine was playing up since the last update and I rebooted it and it was fine. whatsapp however is still messing about.
    07-24-2014 10:30 AM
  3. Limbo13's Avatar
    Hi Steve,
    Yes, i have re-booted and updated etc. I quickly googled this problem just the other day, seems like a few folks around the world have this problem too! But i couldn't find a solution. Seems some with the S4 had this problem whenever the phone was locked/sleeping.
    If u do find a solution, pls tell me!
    07-24-2014 11:00 AM
  4. Fanie Buys's Avatar
    Did you get a solution, because I have the same problem and tis far none of the suggested remedies has any effect!
    10-15-2014 11:29 PM
  5. Limbo13's Avatar
    sorry, nothing
    someone help!!
    10-16-2014 12:52 AM
  6. Limbo13's Avatar
    Am not sure if I've solved this, but this seems to have been working for past 2/3 days.............
    Try to keep WhatsApp "alive" as an "Active app", don't end it, just keep it running in background all the time. Apologies if this is what you do anyway!
    Having said (typed) this, I am sure that it still failed to work on one occassion.............
    12-26-2014 01:45 AM
  7. krish fmw's Avatar
    I am also having the same problem on my S5. I am having this problem very recently and my carrier is Tmobile
    09-26-2015 10:04 PM
  8. FlorisR's Avatar
    I had the same problem. Then I found that if the Battery Saver is enabled, notifications will not be delivered to conserve the battery. Make sure the Battery Saver mode is turned off. On my phone (Sony) I went to settings>Power management and switched the Stamina mode and Low-battery modes off. That seems to have done the trick. Hope it'll work for you as well.
    02-05-2016 05:14 AM
  9. Ashwini Bangar's Avatar
    Finally got a solution for the whatsapp notification problem after many months......
    I am using Samsung Galaxy J7.
    Friends, follow the path:
    Settings->Data Usage->Select Whatsapp-> And make sure Restrict background data is unchecked.
    I did the same. It worked for me.
    Hope it will work for u tooooo.
    rajput naman likes this.
    05-12-2016 01:59 AM
  10. rajput naman's Avatar
    05-13-2016 05:20 AM
  1. Brand new SG S4 Mini with huge battery drain problem.
    By illuSC2 in forum Samsung Galaxy S4 Mini
    Last Post: 12-13-2015, 02:57 PM
  2. Moto G Battery Charging Problem Unable to Fully Charge
    By ADA_Guy in forum Moto G (2013)
    Last Post: 05-21-2014, 11:16 PM
  3. Galaxy S5: problems with loading music to SD card
    By Hewy Puffmister in forum Samsung Galaxy S5
    Last Post: 05-17-2014, 05:11 AM
  4. Moto X: Secondary alarm notification in bar
    By Heavy Fluid in forum Moto X (2013)
    Last Post: 05-16-2014, 12:38 AM
  5. Problems saving videos from iPhone users
    By alil25 in forum Samsung Galaxy S5
    Last Post: 05-15-2014, 04:40 PM
