Results 1 to 13 of 13
Like Tree1Likes
  • 2 Post By puremeerkat
    Nicky_Rizzles's Avatar
    Posts
    Global Posts
    16 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Android OS using large percentage of battery on Galaxy S5
    Turned off sync and its still at 60%
    Any ideas?
    Attached Thumbnails Attached Thumbnails Android OS using large percentage of battery on Galaxy S5-screenshot_2014-05-28-17-47-59.jpg
  2. #2
    bespinct's Avatar
    Posts
    Global Posts
    853 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock!
    Default re: Android OS using large percentage of battery on Galaxy S5
    Um, nothing?
  3. #3
    bespinct's Avatar
    Posts
    Global Posts
    853 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock!
    Quote Originally Posted by bespinct View Post
    Um, nothing?
    Sorry, meant to hit paperclip, hit plane instead.
    Attached Thumbnails Attached Thumbnails Android OS using large percentage of battery on Galaxy S5-screenshot_2014-05-28-21-02-13.jpg
    Posts
    Global Posts
    16 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    71% battery is being used from the kernel I'm not rooted
  5. #5
    puremeerkat's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well it's because you have no other apps running. It's a percentage.
    ExtremeNerd and Aquila like this.
  6. #6
    NickA's Avatar
    Posts
    Global Posts
    2,672 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    I'm surprised at the posts so far saying nothing is wrong.
    Something is wrong. Less than 9 hours on battery and only 44% is not good.
    Did you try to reboot?
    Posts
    Global Posts
    16 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes I have tried to reboot. Its very odd and I can't figure out why its doing this
  8. Thread Author  Thread Author    #8
    Posts
    Global Posts
    16 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You realize that did nothing to help with what's going on with my phone ha
  9. #9
    monicakm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yes, I do realize that. I posted this to the wrong thread. had several open at one time. sorry about that. I deleted it for you ☺
  10. #10
    NickA's Avatar
    Posts
    Global Posts
    2,672 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Try installing GSam Battery Monitor a try and let it run for a day to see what it reports.
  11. #11
    anon(8082935)'s Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My Moto X used to do this pretty bad. I had read somewhere that when you want to take the phone off the charger, turn the phone off, let it boot to battery charging/charged screen, and then unplug it and turn it back on.
    I know it isn't the same phone, but it might be a KitKat bug. It helped me.
  12. #12
    ExtremeNerd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Android OS using large percentage of battery on Galaxy S5
    This isn't odd at all. puremeerkat hit the nail on the head. You have absolutely nothing else running. Something is going to use a large chunk of the battery percent. Your Android OS is artificially inflated because nothing else is using battery at all.
    Go through a standard battery cycle in a day. Browse the internet, play some games, listen to some music, something to make sure more than 4 apps are being reflected in that percentage. Then post the results if you think it isn't normal.
  13. #13
    doubledeckersoulwrecker's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just noticed this today on my S5 also. 92% of the battery usage was android os. Screen was 3% and android system was 2%. Weird thing is I have used Google play and the eBay app alot today. Usually these apps show up on my battery usage screen, but not today. I haven't added any new apps, I've updated a few. Something has changed. Now to find out what
  1. Sign-In Requests after Kit Kat Update on Verizon?
    By kat.hayes in forum Verizon Samsung Galaxy Note 3
    Last Post: 06-02-2014, 03:35 PM
  2. Replies: 22
    Last Post: 06-01-2014, 10:17 AM
  3. How to connect HTC M8 to tv using hdmi?
    By Lilshaq65 in forum HTC One M8
    Last Post: 05-31-2014, 03:30 AM
  4. S5 4.4.3
    By RionDunn in forum Samsung Galaxy S5
    Last Post: 05-30-2014, 12:37 PM
