1. upacrick's Avatar
    When I receive a text, missed call, low battery or charging battery the LED notification light does not come on. I have to keep entering my password to check for messages (not cool at work). If I go settings -> display -> LED indicator the notifications options are all checked.
    Are there any settings that would override or turn off notification lights? I don't see any other settings I need to turn on.
    05-31-2014 03:05 PM
  2. mistaj33's Avatar
    Maybe you could install LightFlow and test your LED. Try the free version for testing. Have you ever seen the LED light up? Does it at least light up when you reboot? If not, maybe it's defective.
    05-31-2014 03:41 PM
  3. upacrick's Avatar
    Yes, the blue does come on briefly when powering down and then back up, but that's the only time it lights up.
    I will give Light Flow a try and see if that doesn't shake something loose. Thanks!
    05-31-2014 06:11 PM
  4. upacrick's Avatar
    Yay! Light Flow is working beautifully. Still don't know why it wouldn't work to start with but will take this nifty little App any day. Thanks again!
    mistaj33 likes this.
    05-31-2014 06:54 PM
  5. Greg C's Avatar
    I highly recommend you buy the paid version if you haven't already. It's a super app.
    05-31-2014 10:24 PM
  6. mistaj33's Avatar
    No problem. Glad you like it. It's definitely one of the first apps I install on any new device or ROM. Can't live without it. Def worth a few bucks.
    Sent from my SM-G900V using Tapatalk
    Greg C likes this.
    05-31-2014 11:17 PM
  7. bungisngis's Avatar
    I have the same issue and it just started yesterday. I haven't installed any new app as I remember. I cannot find the problem why my phone's LED indicators are not working.
    12-09-2014 05:56 PM
  1. text message unread count will not go away
    By xomissbxo in forum Samsung Galaxy S5
    Last Post: 07-24-2016, 07:18 AM
  2. SPECS. Do they cut it for you anymore?
    By Nemesis-X in forum General News & Discussion
    Last Post: 06-11-2014, 05:01 PM
  3. Replies: 2
    Last Post: 06-04-2014, 05:18 PM
  4. Replies: 3
    Last Post: 06-03-2014, 01:14 PM
