1. stargate09's Avatar
    Hi when I enable Air Browse on my S5 it will not work. Not even getting the Air Browse icon on my phone. Please help.
    Avinash Kumar11 likes this.
    06-03-2014 08:46 AM
  2. ahj4513's Avatar
    Go to settings; you will see motions and gesture icon. There you enable air gestures
    Sent from Space Gray design marvel of 2013
    06-03-2014 08:49 AM
  3. stargate09's Avatar
    That's what I did but it's still not working. Thanks though.
    06-03-2014 08:57 AM
  4. ahj4513's Avatar
    One important thing worth mentioning: air browse only worked for me for the standard internet app. It did not work in chrome.
    stargate09 likes this.
    06-03-2014 09:15 AM
  5. novasquid's Avatar
    i can't speak for air gestures, but i do have air wake up turned on. i noticed it's very picky about gestures, and won't work in bright sunlight, even if it's indirect sunlight. it usually won't work either when i'm holding the phone, the phone has to be placed on a surface or held very steady.
    i think the built-in air gestures is mostly gimmicky, but there are apps that seem to work well with it, especially air control that can forward/rewind music tracks based on gestures.
    06-03-2014 09:19 AM
  6. fofjjsr's Avatar
    I haven't had any issues with mine as of yet. But as stated above I believe it only works with the standard Internet app. Not all apps support it.
    Sent from my Galaxy S5
    ahj4513 and stargate09 like this.
    06-03-2014 09:23 AM
  7. stargate09's Avatar
    Thanks a lot. I used chrome. It's working now.
    06-03-2014 09:48 AM
  8. jharo's Avatar
    I only have Chrome on my S5. What is the native browser called?
    06-03-2014 10:04 AM
  9. oreodoh's Avatar
    On mine it's just called Internet. AT&T version here running latest software pushed from the carrier.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    06-03-2014 03:59 PM
  10. scipper77's Avatar
    I think verizon only includes chrome browser. I can't speak for other carriers.
    06-04-2014 01:57 PM
  11. Tom Tillotson's Avatar
    Yes I can't get it either. My volume will not zoom in or out as it's suppose too according to page 90 of the sprint User Guide? Does yours work?
    06-19-2014 08:59 PM
  12. Tom Tillotson's Avatar
    still doesn't work. got everything on and never get a sensor ICON.
    06-19-2014 09:01 PM
  13. Mike Russo1's Avatar
    I'm sure they've tried that lol. I know I have and still not working. It's worked couple weeks ago. Other settings turned on will turn other settings like these off but I've tried everything and still nothing
    #Posted via the Android Central App
    02-26-2015 01:55 PM
  14. Avinash Kumar11's Avatar
    02-27-2015 11:12 AM
  15. Avinash Kumar11's Avatar
    02-27-2015 11:20 AM
  16. samvod's Avatar
    10-05-2015 12:04 PM
  17. Pradi's Avatar
    air browse not support for music player can give d solution... it works for gallery but not working for music player
    10-04-2016 09:16 PM
  18. Ritesh Jha's Avatar
    I am also having problems with my motion sensor after I turned it on. I am having issues as Its eating up my battery, whenever I am keeping my mobile in my pocket, at the slightest of motion it turns on without my knowledge. I tried turning off the motion sensor but my mobile still wakes up at the slightest of motion when kept in my pocket.
    Is there any other way I can put off motion sensor screen wake up??
    10-29-2016 11:28 AM
  1. Replies: 12
    Last Post: 03-28-2015, 12:40 PM
  2. Issue with rotating screen
    By jstwondrng in forum Google Nexus 7 Tablet (2013)
    Last Post: 06-10-2014, 09:26 AM
  3. anyone know?
    By brick58 in forum Samsung Galaxy S5
    Last Post: 06-03-2014, 08:23 AM
  4. Sending Multi media message problems
    By Melaney Barter in forum Samsung Galaxy S II
    Last Post: 06-03-2014, 07:29 AM
  5. Driving Mode getting on automatically as it connects to wifi
    By Akash Agrawal in forum Samsung Galaxy Note 2
    Last Post: 06-03-2014, 06:30 AM
