Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By SpookDroid
  • 3 Post By dpham00
    brick58's Avatar
    Posts
    Global Posts
    153 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default network problem with s5
    My phone keeps going off my network and onto 4g...and nothing wrong with the network cause my mac is still up...anyone know why? It's aggravating because I'm trying to save data at home...
  2. #2
    SpookDroid's Avatar
    Posts
    Global Posts
    11,672 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: network problem with s5
    Is your WiFi set to 'sleep' when the phone is idle? Maybe that's what's causing the disconnect. Or it could be a configuration issue with your router. I know that most Sammy phones have some issues with default router configurations (if you've seen the dreaded "Your connection is unstable" message, more often than not, this is why).
    brick58 likes this.
  3. #3
    dpham00's Avatar
    Posts
    Global Posts
    24,790 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Have you disabled auto network switch in the advanced wifi options?
    Another thing that you can do is to use Tasker or similar to disable Mobile networks at home.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3
  4. #4
    AZgl1500's Avatar
    Posts
    Global Posts
    1,962 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dpham00 View Post
    I 2nd this suggestion.
    I simply turn OFF the data connection.
  1. Using gmail within stock S5 email app
    By konvajw in forum Samsung Galaxy S5
    Last Post: 12-05-2014, 06:13 PM
  2. E-Mail problem/issue
    By JACK DUP in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-13-2014, 12:17 PM
  3. Replies: 3
    Last Post: 06-06-2014, 02:21 PM
  4. Replies: 4
    Last Post: 06-06-2014, 02:07 PM
  5. Samsung Galaxy S5 Keyboard Problem
    By FlipThePancakes in forum Samsung Galaxy S5
    Last Post: 06-06-2014, 01:38 AM
