Results 1 to 5 of 5
    Default camera zoom not working "HELP"
    Also I only have 3 camera modes on my phone!
  2. #2
    Default Re: camera zoom not working "HELP"
    Did you somehow enable Easy Mode?
    LaVerne Boylan likes this.
    I think the recent update to my phone caused the camera problems?????
    thanks!
  5. #5
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by LaVerne Boylan View Post
    thanks!
    Did you accidentally enable easy mode as suggested above? Did disabling that fix your issue?
  1. 13-megapixel camera image samples
    By ChinaOperatingSystem in forum HTC One E8
    Last Post: 07-24-2014, 08:00 PM
  2. Is OK Google Working in 4.4.3 Update for Nexus 5 ???
    By Chaitanya Kumar2 in forum Android 4.4 KitKat
    Last Post: 06-09-2014, 08:37 PM
  3. Using Stock Camera App- Drains Battery Super Fast
    By coachpelkey in forum Sprint Galaxy S3
    Last Post: 06-06-2014, 10:28 PM
  4. Games that uses SD DATA doesn't work after 4.2.2 update.
    By Sourav Sudhi1 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-06-2014, 10:45 AM
