Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By Greg C
  • 1 Post By Greg C
    TheCROW163's Avatar
    Posts
    Global Posts
    302 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Please Help with voice call quality.
    Hi All,
    I'm having a problem with my S5, the caller's voice coming out of the earpiece is very bad in quality: I get a distorted sound and some sound vibration in my ear just like a blown speaker. I'm sure it's not from the carrier as it happens on Viber calls on Wi-Fi as well.
    Is there any way I can adjust the sound? An equalizer app or the like?
    Does Adapt Sound work on the earpiece for voice calls and Viber calls?
    I don't want to send the phone to be repaired under warranty as it will take a long time, so any input is appreciated.
    Thank you kindly.
  2. #2
    Greg C's Avatar
    Posts
    Global Posts
    2,000 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Please Help with voice call quality.
    Quote Originally Posted by TheCROW163 View Post
    Hi All,
    Thank you kindly.
    I set up Adapt Sound and found it made a big difference. I too use Viber and Adapt Sound works very well. It takes about a minute to set up Adapt Sound. Make sure it is very quiet around you when you set it up. Use ear buds when you are setting it up.
    http://www.phonearena.com/news/Make-...-Sound_id43210
    http://global.samsungtomorrow.com/?p=37094
    TheCROW163 likes this.
    TheCROW163's Avatar
    Posts
    Global Posts
    302 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you so much for your reply.
    I'm trying it now, gonna test it with my incoming calls and get back with the result. I really hope it works, cos I believe the problem is with low frequency sounds.
    In the meantime if anyone has any more ideas, please chime in.
  4. #4
    Greg C's Avatar
    Posts
    Global Posts
    2,000 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm trying it now, gonna test it with my incoming calls and get back with the result. I really hope it works, cause I believe the problem is with low frequency sounds.
    You're welcome. Please post how it goes.
    TheCROW163's Avatar
    Posts
    Global Posts
    302 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well it seemed to help a little but I still get some sound vibration at times. It depends on the callers voice.
  1. Lockdown Pro - app lock, lock screen, time pin, observer, send mail
    By kenzi100c in forum Android Security Apps, Tips & Strategies
    Last Post: 07-09-2014, 02:53 AM
  2. Setup Wizard unfortunetly stopped Help Needed Quick
    By Sarvesh Gokarn in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-16-2014, 11:23 AM
  3. Replies: 11
    Last Post: 06-12-2014, 02:16 PM
  4. Help! My SD card blank?
    By heather_dunphy in forum Samsung Galaxy Note 3
    Last Post: 06-10-2014, 11:40 AM
  5. Help to load apps to new phone
    By Tess Trotter in forum General Help and How To
    Last Post: 06-10-2014, 09:23 AM
