Results 1 to 7 of 7
    telrod11's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Flying with the S5 - Data connection issue on landing
    This is a question for those of you who fly with your S5's....
    I'm on AT&T, and the last two weeks in Portland ME and San Francisco, it took after the plane landed and almost to the gate before the S5 connected to data from the network. Now, I'm saying this is slow and unusual, because with previous devices (Iphone 4 / S3), I got data before we even touched down.
    Is anyone getting the same ?
    Any ideas as to why there would be a difference with teh S5?
  2. #2
    sjaduae's Avatar
    Posts
    Global Posts
    316 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Flying with the S5 - Data connection issue on landing
    Quote Originally Posted by telrod11 View Post
    Firstly you should not have your phone on whilst approaching/landing
    I can't say the S5 is any slower than S4 or S3 for searching for new network providers I was trying see if there was a problem on my old S4 and was scanning for providers and it seemed to take a long time and the S5 when manually looking for network providers seemed a little faster
    Try turning off mobile data whilst searching
  3. #3
    AZgl1500's Avatar
    Posts
    Global Posts
    1,962 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Instead of using Airplane Mode,
    just turn OFF data and wifi... accomplishes the same thing and I don't have any problems like that.
    I use the switcher Widget in Battery Doctor, tons of other switchers to do the same.
    telrod11's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, I and all 150+/- of my fellow passengers will cut off the data now... 😆
    This is just really weird, cause I never did anything to any of my other devices, and they sync'ed with the network waaaay before landing...
  5. #5
    JudH's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did you happen to notice the signal strength before data connected? Maybe you didn't have any/enough signal for calls either? Tower down?
  6. #6
    sjaduae's Avatar
    Posts
    Global Posts
    316 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, I and all 150+/- of my fellow passengers will cut off the data now... ...
    The responsible ones will
    I'd go with JudH explanation or weak signal or seat postion
    - - - Updated - - -
    Yes, I and all 150+/- of my fellow passengers will cut off the data now... 😆...
    telrod11's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I made a call to AT&T, and they said they would check my line, and they came back and said nothing was wrong. However, upon return to Atlanta this week, I got data at about 5000 ft or so, just as I used to with other devices, so I'm sure AT&T didn't do anything. (Sarcasm off)
  1. Any one going for the new s tablet
    By Nychotxxx in forum Samsung Galaxy Note Pro 12.2
    Last Post: 06-13-2014, 06:46 PM
  2. Problem with newest update
    By Vyp3rX in forum HTC One M7
    Last Post: 06-12-2014, 07:14 AM
  3. ART Runtime on Moto G
    By Nikhil Ramakrishnan in forum Moto G (2013)
    Last Post: 06-12-2014, 12:54 AM
  4. logitech bluetooth keyboard for ipad, compatibility with android?
    By gargavf in forum General Help and How To
    Last Post: 06-11-2014, 12:45 PM
  5. Problem with headphones
    By Simen Bugge Norum in forum Samsung Galaxy S4 Active
    Last Post: 06-11-2014, 09:46 AM
