1. smalba's Avatar
    The capacitive buttons turn on and I can hear a sound but the screen stays black . I have to keep trying to press the on button until the screen finally lights up after 5 atemps . Does anyone know what could be causing good?
    06-13-2014 01:03 AM
  2. AZgl1500's Avatar
    You must have "Dark Screen" enabled.
    You toggle the screen Dark/ON by tapping the Power Button twice.
    However, if you, like I do, have the screen set to "Instant off and lock" with a single touch of the Power button, the Dark Screen feature "should be" disabled.
    I suggest you hold down on the Power button a long time and the Restart screen should appear. That will let you recover usually.
    Do you have Samsung SideSync installed on the phone? If you do, you can plug the phone into the USB cable and connect to your desktop PC and gain access to the phone that way. (Requires the OEM USB 3.0 cable)
    I included a screenshot showing that it is disabled on my phone.
    I also included an image of SideSync running on my PC and showing the same exact screen.
    Attached Thumbnails Screen doesn't turn on when I press the home or power button.-dark-screen-option.jpg   Screen doesn't turn on when I press the home or power button.-dark-screen-image-sidesync.png
    06-13-2014 05:48 AM
  3. smalba's Avatar
    Well i can get the screen to turn on after a few tries it's just really annoying. I'll check those settings and report back.
    06-15-2014 09:47 AM
  4. Marina Bumber's Avatar
    Mine is turned off but I have the same exact problem. Usually it lights up after I press power button the second time. Really annoying. Capacitive buttons light up but the screen stays dark.
    I rest my case.
    diamondRanch likes this.
    06-15-2014 03:55 PM
  5. diamondRanch's Avatar
    Mine does the same thing, dark screen is NOT problem, lots of people complaining on this
    06-15-2014 08:50 PM
  1. Free Screen Repair!
    By Cane Prevost in forum Moto X (2013)
    Last Post: 08-04-2014, 12:44 PM
  2. Unable to turn on Swiftkey. What's going on?
    By CannedBullets in forum HTC One M8
    Last Post: 06-13-2014, 07:06 PM
  3. Unable to bypass lock screen on my note 2
    By jamshed taraporwala in forum Samsung Galaxy Note 2
    Last Post: 06-13-2014, 01:04 AM
  4. AUTOMATIC Turn ON when plugged in/charging
    By RaidenVS in forum General Help and How To
    Last Post: 06-13-2014, 12:17 AM
  5. I LIke The New Look Webby :)
    By monicakm in forum Samsung Galaxy S5
    Last Post: 06-13-2014, 12:16 AM
