1. gabrielxavila's Avatar
    Need help guys I've switched over from a jailbroken iphone, so im new to androids and dont know much. I recently download 3 sms blocker/ filter apps and after deleting all 3 apps my notification led will not work. My led lights up when im charging, but will turn off when the screen is lit. I did the obvious and ensured led settings were turned on. Went to my files and found a file that was left behind from one of the sms apps and deleted it, still nothing. If anyone can help me figure out whats going on it would be greatly appreciated!
    Thanks
    06-13-2014 10:57 AM
  2. mhunter6378's Avatar
    Could be some left over processes from those apps. When I have installed / uninstalled lots of apps and had glitches I usually wipe the cache partition and that generally solves the problem. You may want to give it a try, it won't delete any of your files.
    To wipe the cache partition, follow these steps:
    Turn off the device.
    Press and hold the following three buttons at the same time:
    Volume Up key
    Home key
    Power key
    When the phone vibrates, let go of the Power key but continue to press and hold the Volume Up key and the Home key.
    When the Android System Recovery screen appears, release the Volume Up and Home keys.
    Press the Volume Down key to highlight 'wipe cache partition.'
    Press the Power key to select.
    When the wipe cache partition is complete, 'Reboot system now' is highlighted.
    Press the Power key to restart the device.
    06-13-2014 11:16 AM
  3. gabrielxavila's Avatar
    Volume Up key
    Home key
    Power key
    You are the man it worked! Thank you so much it was driving me crazy, and I do t quite speak the android language yet. Thanks again partner!
    06-13-2014 01:26 PM
  4. mhunter6378's Avatar
    You're welcome, glad it helped.
    06-13-2014 01:48 PM
  1. How to change voicemail greeting on att galaxy s5 Att
    By speed13 in forum Samsung Galaxy S5
    Last Post: 10-08-2015, 12:44 PM
  2. How do I make my S5 look more sexy?
    By Bayarea13 in forum Samsung Galaxy S5
    Last Post: 06-17-2014, 11:45 PM
  3. Multi Window Not Working
    By gaffers01 in forum Samsung Galaxy S5
    Last Post: 06-16-2014, 07:10 AM
  4. google now not working
    By yeshan2015 in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 06-13-2014, 11:09 AM
  5. S5 - Google Addition
    By KBV1 in forum Samsung Galaxy S5
    Last Post: 06-13-2014, 05:15 AM
