Results 1 to 5 of 5
    Default Text notification sound app problem
    So I got an app to download new ones, I found one I liked so I got it but the only problem is that it downloaded into my music library. Is there any app that doesn't put the ring tones into the music library and puts it into the ringtone list?
    Posted via S5
  2. Thread Author  Thread Author    #2
    Default Re: Text notification sound app problem
    Anyone know how to get new ones without them downloading into my music player?
    Posted via S5
  3. #3
    Quote Originally Posted by Patchyy94 View Post
    Posted via S5
    That's not possible.
  4. #4
    I use Zedge
    https://play.google.com/store/apps/d....android&hl=en
    Sound files downloaded through this app will show up in you sound file list with all the native sounds. For instance, if you download a new notification sound file through Zedge and then open your messaging app, select settings>notifications>notification sounds, you will be presented with two choices, media storage and Zedge. If you select media storage you will see the list of your native sounds and the newly downloaded sound file from Zedge will be in the list with your other sounds.
    Patchyy94 likes this.
    Quote Originally Posted by mhunter6378 View Post
    I use Zedge
    Thank you so much I'm going to check that out now
    Posted via S5
  1. latest youtube app not compatible with the lg ms690
    By Androidbot101 in forum LG Optimus M
    Last Post: 06-15-2014, 02:10 PM
  2. Replies: 10
    Last Post: 06-14-2014, 07:25 PM
  3. Samgsung Note 3 Apps
    Last Post: 06-14-2014, 03:28 PM
  4. clicking noise when typing or texting
    By Unregistered in forum Ask a Question
    Last Post: 06-14-2014, 02:12 PM
  5. Clock app frequently keeps phone awake/wakes up phone when alarm is set
    By icouldntpossiblycomment in forum Samsung Galaxy S5
    Last Post: 06-14-2014, 01:33 PM
