1. Gambit11B's Avatar
    New to the forum, and Android. Just got a new S5 Active (ATT) last week, and have noticed on at least 3 occasions where the phone's audio stopped working in multiple applications (unlocking phone, you tube, notifications, games). A simple reboot fixed the problem, but I can see this becoming a nuisance after awhile.
    Is this a known issue with either the phone, or software???? If so, is there something else I can do to prevent it???? If not, should I return it to the store and get another (if hardware problem)????
    Thanks!!!!
    06-16-2014 12:31 PM
  2. PsychDoc's Avatar
    Definitely not a common problem. As much as I hate to suggest it a factory reboot may be your best option. If it still does what you describe you need to exchange it.
    Sent from my SM-G900V using AC Forums mobile app
    TenshiNo likes this.
    06-16-2014 01:03 PM
  3. Gambit11B's Avatar
    Thanks for the speedy response. I guess I'll need to return to the store.....
    06-16-2014 01:37 PM
  4. TenshiNo's Avatar
    Unfortunately, when you manufacture millions of something, some percentage are destined to have some kind of issue. Sorry to hear you got one of the "bad" ones. I agree that you should definitely look at getting it replaced.
    06-16-2014 05:35 PM
  1. Audio problems with headphones.
    Last Post: 06-15-2014, 11:32 PM
  2. how do you like the headphone audio quality?
    By sdsubball23 in forum Samsung Galaxy S5
    Last Post: 06-15-2014, 11:45 AM
  3. can Moto X read wma audio files (books)
    Last Post: 06-14-2014, 04:23 PM
  4. video I took on my S5 won't play audio :(
    By critter1780 in forum Samsung Galaxy S5
    Last Post: 06-13-2014, 10:18 PM
