Results 1 to 2 of 2
    acclaim99's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default more battery issues
    So my S5 used to fast charge (90 mins full charge), now I can only charge at 450mA, and my battery barely makes it through a work day.
    The charger has that spot near the usb that Is bent and showing... Dunno if that's the problem, or is the battery messed up, or do I need a reset?
    Copied off my fb. But it seems to have started around the time when I used , not the full size charger, just the one that plugs in the right.
    Although. I got a text I used 90% of my data in 5 days. Not touching my phone. Email used like .70 of a gb somehow.
  2. #2
    Kelly Burby's Avatar
    Banned
    Posts
    Global Posts
    706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: more battery issues
    Quote Originally Posted by acclaim99 View Post
    Well, do one thing remove the battery put it over to the flat surface try spinning it, if the battery spins means it's swollen and needs replacement but if it doesn't then try going onto the setting>battery and check which application is draining most of your battery. and do one more thing read about the "What sucks your Android battery?" This will help you in understanding the reason behind the excessive battery usage.
  1. Replies: 13
    Last Post: 10-14-2015, 04:19 AM
  2. Replies: 5
    Last Post: 02-12-2015, 04:33 AM
  3. Battery wifi issues
    By RionDunn in forum Samsung Galaxy S5
    Last Post: 06-26-2014, 12:57 AM
  4. Can Fire OS make android more efficient?
    By Christopher Senn1 in forum Amazon Fire Phone
    Last Post: 06-24-2014, 04:42 PM
  5. Tips for conserving the longevity of the Nexus 5 battery?
    By perhac181 in forum Google Nexus 5
    Last Post: 06-18-2014, 05:23 PM
