Results 1 to 6 of 6
Like Tree4Likes
  • 1 Post By PsychDoc
  • 1 Post By mhunter6378
  • 2 Post By williams448
  • 1 Post By ibcop
    tony5496's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Help with microSD cards
    Hi all I am just looking to get microSD card for the Galaxy S5 I was just wondering if someone could help me out. I am looking at the 64 GB but I'm very confused about the class what does the class main class six class seven class ten ! it's all very new to me any help would be great and if you could recommend a good one to get for the s5
  2. #2
    PsychDoc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Help with microSD cards
    You want a class 10. Any of the major names should be good although I've heard some complaints about San Disc cards failing after a few months. If I were getting one I'd probably stick with a Samsung branded card.
    Amazon.com: Samsung Electronics 64GB EVO Micro SDXC with Adapter Upto 48MB/s Class 10 Memory Card (MB-MP64DA/AM): Computers & Accessories
    Here's a 64 GB Samsung one for $40. Don't see how you can beat that.
    tony5496 likes this.
  3. #3
    mhunter6378's Avatar
    Posts
    Global Posts
    1,262 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The class of the the card basically boils down to the read/write speed, the higher the class the faster the card. I've always used SanDisk, using one now 32gb Ultra, never had a problem but others have reported some issues. Stay with the leading top brands and you should be fine. And that really is a good deal on that Samsung card posted by PsychDoc!
  4. #4
    williams448's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I'm currently using, and have had no problems out of this Sony card. The 64GB can be had for $40 as well, Class 10. I got the 32GB for $20.
    It also comes with an SD card adapter.
    http://www.amazon.com/gp/aw/d/B00BW6...cUvbUpU3721010
    Posted with my badass Galaxy S5
    tony5496 and pelon0427 like this.
  5. #5
    ibcop's Avatar
    Posts
    Global Posts
    6,065 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    mhunter6378 likes this.
  6. #6
    jmagid51's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just asked the same question in this forum and decided to by the SanDisk Ultra 64 Gb card for both my S5 and Tab 3.0. Speed was not really a consideration but high reliability was. Good luck.
    Sent from my SAMSUNG-SM-G900A using AC Forums mobile app
  1. Help
    Last Post: 06-20-2014, 10:21 AM
  2. HELP!!!
    Last Post: 06-20-2014, 09:33 AM
  3. Help, need to unroot phone
    By Matthew Zepess in forum Ask a Question
    Last Post: 06-20-2014, 09:22 AM
  4. please help!
    By Roxxygen in forum LG G2
    Last Post: 06-20-2014, 08:11 AM
  5. Replies: 0
    Last Post: 06-20-2014, 01:45 AM
