1. Grakekiru's Avatar
    First problem, I've had my Galaxy S5 for a few weeks now but just a few days ago the "check battery cover" has been popping up every single time I unlock my phone. EVERY SINGLE TIME. No, not when I unplug it from charging or when I turn it on and off, it's every time I unlock it.
    Second problem, I keep getting a notification that my SD Card is blank or loose. IT'S NOT. But this one comes and goes, I just want it to STOP! It's REALLY annoying.
    I've restarted the phone, checked the back cover, made sure every corner clicked literally like 50 times, and the notifications STILL come up! I'm not rough with my phone at all, so there's no way I must've knocked some sensitive part on the back. I called Samsung Support and not even THEY knew how to fix it!
    I'm not new to android and I do NOT want to restore to factory settings.
    PLEASE HELP! I'm very sure others have had this problem too.
    06-21-2014 02:51 AM
  2. TechGod2014's Avatar
    You need to restore to factory settings and see if it happens again. If not it may be an app or file causing this problem. I would install your apps one at a time to make sure it's not the one causing this issue.
    Good luck.
    Sent from my SM-G900T using AC Forums mobile app
    06-21-2014 06:28 AM
  3. PsychDoc's Avatar
    As it sounds like a misbehaving app why don't you start uninstalling apps you've recently downloaded and see if that clears things up. I say this because you indicated that things were fine until a few days ago. To me that says there's an app behaving badly. Otherwise I'm afraid you'll habe to resort to the dreaded hard reset.
    06-21-2014 06:58 AM
  4. Grakekiru's Avatar
    I haven't downloaded any apps recently. I deleted all apps I've downloaded (which were about 10). The message stopped popping up for about an hour, but it came back! Also, the notification icon still shows up saying my SD Card is blank. :/
    06-22-2014 06:07 PM
  5. Grakekiru's Avatar
    I'm afraid of restoring it and seeing the same problems :/ If I find no other alternatives I will have to restore the phone
    06-22-2014 06:09 PM
  6. jonebk12's Avatar
    My guess is a hardware issue with the SIM card and/or its slot. I'd get a replacement if a factory restore doesn't fix the problem.
    06-22-2014 07:19 PM
  1. Samsung Galaxy S6: What we want to see
    By TechTube14 in forum Samsung Galaxy S6
    Last Post: 12-05-2014, 12:57 PM
  2. Replies: 1
    Last Post: 08-25-2014, 08:33 PM
  3. Gorilla gadgets 5800mah extended battery
    By ryanr509 in forum Samsung Galaxy S5 Accessories
    Last Post: 08-21-2014, 07:44 PM
  4. Replies: 2
    Last Post: 06-21-2014, 02:29 AM
  5. Galaxy note2!!!! :(((
    By sariyaht@gmail.com in forum Ask a Question
    Last Post: 06-21-2014, 12:15 AM
