1. italiano7's Avatar
    Have read about a but on here and followed the tips but battery even after factory reset is draining fast
    Anything suspicious?
    06-22-2014 02:12 AM
  2. italiano7's Avatar
    85% but only a hour left?
    06-22-2014 02:13 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! That screenshot isn't entirely helpful. It'd be better to see the screen with the graph, your total screen-on time, and the Cell Standby category (if present) to see your Time without Signal. Wait until the battery has dropped to about 30-40% before taking the screenshots.
    Should I assume you reviewed the battery tips here? [Guide] Battery Saving Tips
    You could try removing your SD card, since corrupt files on the SD can cause problems. Go to Settings>Storage​ and Unmount the card, then remove it and reboot.
    06-22-2014 02:21 AM
  4. italiano7's Avatar
    Hi
    Yes reviewed all that
    Don't have a sad card
    How do I get the screen shot you require
    Thx
    06-22-2014 02:32 AM
  5. WhiteiPadMini's Avatar
    the 1 h 35 m does not mean you have 1 hour 35 min. left before it dies. It just means that your phone has been unplugged since then. In this case, 1 h 35 m. ago.
    Jaramie10 likes this.
    06-22-2014 02:47 AM
  1. GSam Battery monitor users
    By S5_GJH in forum Samsung Galaxy S5
    Last Post: 07-12-2015, 08:38 AM
  2. HTC One X Battery Draining Overnight
    By Sheriff Woody in forum HTC One X
    Last Post: 06-25-2014, 01:04 PM
  3. My galaxy s4 shows 0% battery even with full charge
    Last Post: 06-21-2014, 06:54 PM
  4. Samsung galaxy s5 battery losing charge rapidly
    By Unregistered in forum Ask a Question
    Last Post: 06-21-2014, 12:03 PM
  5. Strange battery drain, overheating with no wakelocks
    By mamdoj1 in forum Samsung Galaxy S5
    Last Post: 06-21-2014, 11:02 AM
