1. woahohkelsey's Avatar
    I just got a wireless charging pad/receiver, so I don't have to use the flap anymore. However, I feel like it's gotten a little loose as it opens up sometimes randomly. Should I tape it down or what can I do?
    06-23-2014 08:20 PM
  2. guitarfish's Avatar
    Mine doesn't seal well either. You can find new covers on eBay for a few bucks each, but they come from China so it may take a w.eek or more.
    06-23-2014 08:43 PM
  3. Sophia Zhao's Avatar
    You can get more infomation here
    Charger Cover Broke
    06-23-2014 09:11 PM
  4. Greg C's Avatar
    If you are careful around water than I wouldn't worry about it. To get a replacement cover is going to cost around $19. That's a lot considering what it is.
    06-23-2014 10:44 PM
  5. bembol's Avatar
    I know $20 is ridiculous but IMO it's not worth risking, even if you do tape it up.
    06-23-2014 11:39 PM
  6. guitarfish's Avatar
    Genuine Samsung replacements on eBay for about $6 shipped.
    06-24-2014 11:14 AM
  7. zerrisk's Avatar
    Where did you find these? Can you link one please?
    06-24-2014 04:57 PM
  8. guitarfish's Avatar
    06-24-2014 05:07 PM
  9. AZgl1500's Avatar
    bad link
    just copy the words from his link and paste into the eBay search line.
    there are many listings from $3.99 and up
    Galaxy S5 USB Cover OEM | eBay
    This is the way the search looked when I copied the link I created.
    zerrisk likes this.
    06-24-2014 06:49 PM
  10. guitarfish's Avatar
    Link has been corrected, sorry.
    06-24-2014 06:51 PM
  11. zerrisk's Avatar
    Hi thank you very much for the links! Just ordered one for myself in hopes to fix a loose port cover. Had anyone had success with these?
    Posted via Android Central App on my Samsung Galaxy S5, please excuse the brevity.
    06-25-2014 05:17 PM
  12. guitarfish's Avatar
    06-25-2014 05:23 PM
  13. zerrisk's Avatar
    Thank you! I'm just a little concerned if it's really OEM or not. I'm afraid the ip67 rating for water resistance will be safe as I plan on taking this phone to the pool and beach this summer.
    06-25-2014 07:20 PM
  1. Can transfer files to Tablet Azpen 727
    Last Post: 10-18-2014, 03:36 PM
  2. Replies: 3
    Last Post: 09-22-2014, 04:16 PM
  3. System keeps hanging after update
    By babracmmm in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-04-2014, 09:35 AM
  4. In case you're wondering how tough the S5 is
    By guitarfish in forum Samsung Galaxy S5
    Last Post: 06-26-2014, 12:47 PM
  5. my Google Play fails to install apps
    Last Post: 06-23-2014, 11:28 PM
