1. Halifax's Avatar
    So I used to have an S3, and its camera had a macro focus mode, which worked really well for taking pictures up close of things. There appears to be no macro focus mode option on the S5, and it just can't focus on close-up objects, despite how when it tries to focus I see the object in focus momentarily and the focus it ends up on is terribly blurry.
    I know it can focus on objects this close, but the auto-focus refuses to do it. It takes at least a full second to auto-focus each time, and having to try to get the auto-focus to work for 10-15 seconds before giving up is very annoying.
    07-06-2014 05:46 PM
  2. thecomicbookandme's Avatar
    I have the exact same problem. 😡
    Any help out there? 😨
    07-06-2014 08:50 PM
  3. AZgl1500's Avatar
    Put it in manual focus mode....
    I tried it just to see how it works.
    All of my stuff is landscapes, broken bridges and broken highways... no macro needed.
    07-06-2014 08:58 PM
  4. jonebk12's Avatar
    Mine does pretty well taking macro photos even without a dedicated mode. I can get up close and focus on objects that are only a few inches away.
    07-06-2014 09:11 PM
  5. Halifax's Avatar
    How exactly do you put a phone into manual focus mode?
    07-06-2014 10:57 PM
  6. monicakm's Avatar
    my phone has focused from about 2 1/2 inches for a sharp macro. I posted it to this forum. I'll see if I can find it.
    07-07-2014 12:34 AM
  7. giodomin91's Avatar
    Same problem here. It's very annoying
    Sent from my SAMSUNG-SM-G870A using AC Forums mobile app
    07-07-2014 12:56 AM
  8. Halifax's Avatar
    It's not that I don't believe you, I'm just confused why mine can't seem to do that. I just took a picture and couldn't get it to focus from less than four inches. That's not bad but I used to take macro photos from my S3 all the time that looked really nice.
    Okay, in trying to test this I went to take another picture and it focused from two inches, but only once and then it couldn't do it again.
    07-07-2014 05:51 AM
  1. Email not working.
    By jimmyvh in forum AT&T Galaxy Note 2
    Last Post: 07-09-2014, 06:53 PM
  2. Soft keys not working at all on Galaxy S5
    By Unregistered in forum Ask a Question
    Last Post: 07-07-2014, 12:42 PM
  3. Google Now doesn't understand
    By Edible Walrus in forum Samsung Galaxy S4
    Last Post: 07-06-2014, 04:43 PM
  4. acer b1 micro sd card not working
    Last Post: 07-06-2014, 03:25 PM
  5. Flash and Wallet do not work on my Galaxy S4
    Last Post: 07-06-2014, 01:58 PM
