Results 1 to 16 of 16
    Default Why does my phone "stay awake" all night long killing battery?
    battery - android os - stay awake 8 Hours
    Is what i see in the morning after I have charged to 100% the night before, now 8 hours later it is 50%, it has been in airplane mode this entire time...
    What the heck?
    Is there a button to push that makes the phone NOT stay awake all night long?
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,748 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Why does my phone "stay awake" all night long killing battery?
    Quote Originally Posted by Randy Shaw View Post
    What the heck?
    Can you post screenshots of the battery stats and the graph, please?
  3. #3
    bbmjack's Avatar
    Posts
    Global Posts
    811 Global Posts
    Am sure that your phone was on white screen
    they arent there now as new stats are there, i maybe could do it tomorrow morning, what it does say is stay awak 8 hrs, which obviously is what is the problem i just dont know if there is a way to make it not stay awake, thanks, will try and get that pic later
    - - - Updated - - -
    if i knew what white screen meant i might be able to figure out how to change that?
    cant find "white screen" anywhere, so i guess that is not helpful
    Is there a stay awake option, somewhere on my phone, that I can UNcheck?
    seems the s4 or s3 did have that, does the s5 NOT have the option to turn on or off stay awake?
    pulled battery for 30 seconds and put it back in, this morning it had 96% left after sitting all night and the stay awake message was gone, idle or something is what it said
  7. #7
    Also if you enabled developer options there is a box you have to check that says something along the lines of phone will never sleep while plugged in. I'd check that first.
  8. Thread Author  Thread Author    #8
    As I understand it, developer options is something you could access in prior versions, but the s5 you cant without setting it up, it is not in my menu...i did take the battery out for a minute and put it back and now i am back to normal
  9. #9
    OK I have it set up on mine and figured I would throw out another possibility for you to check. No worries.
  10. #10
    Three7s's Avatar
    Posts
    Global Posts
    81 Global Posts
    That is NOT correct.
  11. #11
    Why would you charge your phone just to take it off while you are sleeping? Most people charge their phone while they sleep them have a full charge when they get up.
    Sent from my LGLS990 using Xparent BlueTapatalk 2
  12. #12
    Quote Originally Posted by Topgonzo View Post
    It might just be an old wives tale but I've always been concerned that leaving it on the charger after the phone is fully charged will wear out the battery faster. The thing charges so fast that I just plug it in an hour or two before I go to bed and it only loses 5% max while I sleep.
  13. #13
    Quote Originally Posted by jonebk12 View Post
    If u really want amazing battery life while u sleep put the phone in ultra power saving mode, shuts down everything in the background that goes crazy at night. So your apps updating, email synching, synch services, back ups, game notifications etc is all stopped. In my test on this mode I may lose 1% over night and that is it.
  14. Thread Author  Thread Author    #14
    Oh, so how do you access developer options on s5?
  15. #15
    I never charge my phone while I sleep, I always top it off before I go to bed. I'm not sure why I do that, I guess I'm just so used to that method
    Posted via Android Central App on my Note 3
  16. #16
    msndrstood's Avatar
    Posts
    Carrier
    Stock JB 4.1.2
    Every other Android phone I've ever had works by tapping on the Build Number 7 times under About Phone.
  1. Phone in car
    By Karleen77 in forum Samsung Galaxy S5
    Last Post: 07-14-2014, 05:28 AM
  2. I created my new game - addictive!!
    By Idan Uzan in forum Android Games
    Last Post: 07-13-2014, 05:00 AM
  3. Two minor questions with new(used) phone...
    By double_0_7 in forum Droid RAZR M
    Last Post: 07-10-2014, 11:00 AM
  4. My Samsung Galaxy Tab 2 7.0 won't boot
    Last Post: 07-10-2014, 09:15 AM
  5. Replies: 1
    Last Post: 07-10-2014, 07:47 AM
