Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By ibcop
    Default 2nd Power Cable Needed
    Looking for a spare power cable for the S5. Anyone know where they may be available and what they may cost? Thanks in advance for the help.
    Sent from my SAMSUNG-SM-G900A using AC Forums mobile app
  2. #2
    Default Re: 2nd Power Cable Needed
    The USB 3.0 cable?
    I'm buy my cables at monoprice. IIRC it's less than $6.
    Pro S5
    Yes, the USB 3.0 cable.
  4. #4
    ibcop's Avatar
    Posts
    Global Posts
    6,064 Global Posts
    Carrier
    Stock
    Amazon
    lgdlman likes this.
    Any price for Amazon?
  6. #6
    Quote Originally Posted by jmagid51 View Post
    USB 3.0 Amazon S5
    Thanks !!
  8. #8
    Thanks !!
    You get what you pay for.....I bought three two months ago and one doesn't work now...
  9. #9
    bbmjack's Avatar
    Posts
    Global Posts
    811 Global Posts
    Quote Originally Posted by Jon Jackson View Post
    I'm planning to get it but tell me how fast it does charge the phone ?
  10. #10
    Quote Originally Posted by bbmjack View Post
    0 to 100% in about 80-90 minutes. It's a little more than 1% a minute for me. The only charger where someone comes over and says I need to charge my phone for 10-15 minutes and that literally can last them the entire night.
  11. Thread Author  Thread Author    #11
    I have also been getting about 1% per minute using the stock cable and charger.
  12. #12
    It all depends on how much load the phone is currently under while it's being charged. Putting your phone on Airplane mode will speed up charges a bit, turning EVERYTHING on (Wifi, Data, Bluetooth, location, brightness, etc) will slow charging times down
    I've seen everything from one percent per minute to 1 percent per 4 minute increment, it just depends on the load.
  13. Thread Author  Thread Author    #13
    You are 100% correct. The way I obtained the 1% per minute was to shut the device off for 90 minutes when the power level was 10%. At the 90 minute mark I turned the device back on and I was at 100%. Thanks for keeping us honest.
  1. Is There a Free Screen Recorder That Does Not Need Root?
    By eddie39 in forum General Help and How To
    Last Post: 07-10-2014, 07:06 PM
  2. noob needs help
    By unlvjeffro in forum Sprint Galaxy S3
    Last Post: 07-10-2014, 01:03 PM
  3. Need help
    Last Post: 07-10-2014, 12:14 PM
  4. Need an inexpensive but good android for my 14 yo daughter
    Last Post: 07-10-2014, 08:43 AM
  5. Galaxy S3 won't power on
    By kirbyg53 in forum Ask a Question
    Last Post: 07-09-2014, 11:20 PM
