1. Manfred Jarvis's Avatar
    I want to shoot video in "smooth motion" mode and at -1 exposure setting, but every time i return back to the camera app it's defaulted back to "normal mode" and 0 exposure.
    Is there a way to lock my settings permanently, until i chose to unlock them?
    07-11-2014 12:36 PM
  2. Rev2010's Avatar
    Most settings do stick, but I too have found the 60p (smooth motion) does not stick and it's rather annoying. Now I have to change the settings every time before I start a video since I shoot everything across all my cameras in 60p. Not the end of the world, but I've had to stop a recording and retake once I realized I forgot to change the setting once or twice.
    Rev.
    07-11-2014 01:05 PM
  3. Manfred Jarvis's Avatar
    so i take it that theres no way to make these setting stick? not even with a 3rd party app if one existed that is.
    07-11-2014 01:15 PM
  4. Rev2010's Avatar
    I searched around online and couldn't find any way to make the settings stick, even posted about it on here a few months back or so. As for 3rd party apps, I have no idea. I'd imagine a 3rd party app would need to be specially made for the S5 for it to have its specific settings available, never bothered to check in the app store.
    Rev.
    07-11-2014 01:18 PM
  5. jmagid51's Avatar
    I go through the settings each time I'm going to set up to take pictures. Most stick but there is always the one that doesn't.
    Sent from my SAMSUNG-SM-G900A using AC Forums mobile app
    07-11-2014 04:00 PM
  6. jmagid51's Avatar
    I spoke with a rep from Samsung and was told they were working on a way to make sure all settings would stick. It's not only the camera as they seem to imply it was a general problem.
    07-11-2014 05:21 PM
  7. atishc's Avatar
    This is not an answer to your problem, but as an FYI in case you did not know, the three quick setting toggles on the left can be replaced with any of the settings in the large menu by dragging the setting from the menu onto one of the toggles. In your case, I would put "Recording Mode" and "Exposure" in your quick settings so you don't have to go into the menu every time.
    07-12-2014 10:48 AM
  1. What is the latest software update for the Android 4.3?
    By AC Question in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-13-2014, 04:41 AM
  2. G2 won't connect to data
    By Notasoccerstar09 in forum Verizon LG G2
    Last Post: 07-12-2014, 12:19 AM
  3. How do I sync to Google Calendar not Outlook?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 07-11-2014, 12:52 PM
  4. Replies: 0
    Last Post: 07-11-2014, 12:31 PM
  5. How do I delete updates on the Samsung Galaxy S4?
    By maryna mouton in forum Samsung Galaxy S4
    Last Post: 07-11-2014, 12:25 PM
