1. Dominic Lynch's Avatar
    Hey so I decided that you guys helped me with my messaging problem so ill greet you guys withy BATTERY LIFE PROBLEM
    So any help would be appriciated I.e your settings and proof of it working
    THANKS AGAIN
    07-12-2014 02:48 PM
  2. msavic6's Avatar
    It's hard to help you without knowing what's wrong. Provide us screen shots of your battery life stats and provide screen shots from GSAM, only then will we be able to help you out.
    Sent from my SM-G900W8 using Tapatalk
    07-12-2014 02:49 PM
  3. Dominic Lynch's Avatar
    It's really annoying is there any way to reduce the amount of battery youtube uses . I charged it to 100 percent 3 hours ago and down to 67 percent 😑
    Attached Thumbnails Battery life not impressive-screenshot_2014-07-12-20-58-59.jpg   Battery life not impressive-screenshot_2014-07-12-20-59-17.jpg   Battery life not impressive-screenshot_2014-07-12-20-59-27.jpg
    07-12-2014 03:01 PM
  4. monicakm's Avatar
    I get close to 2 days on a full charge. Screen time is generally 4 hours. I have all the things enabled that people say to disable (GPS, Sync, etc). I removed a few apps that I wouldn't use but I don't think they were anything that would drain the battery anyway. Everyone's needs and uses are different. I'm not a heavy user.
    lgdlman likes this.
    07-12-2014 03:13 PM
  5. Dominic Lynch's Avatar
    I'm heavy to rear extreme when at home which I know that it will drain battery then but when I'm in town like to town watched a half an hour video and bam 34 percent gone like WTF😣😮😡😧😢😨
    07-12-2014 03:19 PM
  6. AZgl1500's Avatar
    Use WiFi instead of DATA for watching videos.
    DATA requires the phone's transmitter/receiver to be active which requires battery power.
    WiFi is very frugal of battery use.
    07-12-2014 05:41 PM
  7. Three7s's Avatar
    The screen shot shows that for over 3 hours your screen was on, wake locks are solid as is Wifi. Not sure how long you were actually streaming content during that timeframe, but I think you need to use external power doing all this, if you expect to get decent battery life.
    07-12-2014 06:37 PM
  8. rc75149's Avatar
    Just looking at all those active apps in your bar would answer why your battery life sucks
    07-12-2014 08:25 PM
  9. Dominic Lynch's Avatar
    Ya just reset the device and not as many open activities
    07-13-2014 05:22 AM
  10. jonebk12's Avatar
    Reduce the amount of battery YouTube uses by not watching videos for 3 straight hours. I'm not really sure what you expected. It's unrealistic to think the phone should last all day when you have the screen on constantly.
    07-13-2014 05:35 AM
  11. Dominic Lynch's Avatar
    I didn't have the device on for 3 hours straight I was in town was 3 hours and while waiting for my friend I watched a 30 min video and lost like 34 percent explain that hot shot
    07-13-2014 10:42 AM
  12. jonebk12's Avatar
    I say you had the screen on for 3 straight hours because that's exactly what the last screenshot you posted indicates. The blue bar under where it says "screen on" is lit up for almost the entire 3+ hours you had the phone on battery.
    07-13-2014 11:32 AM
  13. msavic6's Avatar
    Post your screen on time...we can attempt to decipher it ourselves from the graph but apparently our assumptions are wrong.
    07-13-2014 02:53 PM
  14. Dominic Lynch's Avatar
    Hmm u guts are actually right I'm very sorry my screen was on the whole time we'll dammit well again u guys are amazing in helping thx again
    07-13-2014 05:26 PM
  15. kingnothing's Avatar
    I just checked mine and I'm at about 11 hours and most of usage is from Android system. 13% of battery usage was android system. Is that normal?
    07-13-2014 05:53 PM
  1. Quick Remote Not Working
    By oldrtyfrog in forum LG G3
    Last Post: 02-23-2017, 07:28 AM
  2. Replies: 1
    Last Post: 07-12-2014, 02:41 PM
  3. Blue lights not working on top of screen
    By cobz in forum Motorola Droid Ultra
    Last Post: 07-12-2014, 01:46 PM
  4. App Not Compatible.
    By bcxx143 in forum Ask a Question
    Last Post: 07-12-2014, 01:45 PM
  5. Voice navigation not working on HTC One M8??!!
    By ddetmer222 in forum Ask a Question
    Last Post: 07-12-2014, 01:13 PM
