1. Julio Esteves's Avatar
    Love My Galaxy S5 , But I Knew Eventually That This Charger Port Was Going to Be A Problem ! Anyone Have A Suggestion For Where I Can Find A Replacement Cover ? Thanks
    07-16-2014 04:01 AM
  2. Greg C's Avatar
    Here's the thread that discusses this issue:
    Charger Cover Broke
    Sent from my Samsung Galaxy S5
    07-16-2014 04:05 AM
  3. bbmjack's Avatar
    1st how long you had the usb door
    2nd there is in amazon
    07-16-2014 04:05 AM
  4. Julio Esteves's Avatar
    Thanks
    07-16-2014 04:10 AM
  5. Julio Esteves's Avatar
    Only 2 Months But I See The End Where You Seal The Charger Port , The Black Strip Is Missing , And I Can Tell That The Port No Longer Closes How It Used To
    07-16-2014 04:11 AM
  6. bbmjack's Avatar
    But I highly recommend you to get witless charging and relax and I'm ordering one soon I'm a bit scared to break it . Because this usb port same as finger nails hard to cut
    07-16-2014 04:40 AM
  1. 4.4.2 SD Card problem
    By BigB0SS in forum Ask a Question
    Last Post: 09-07-2014, 02:11 AM
  2. New Google Search and BT Dialing Problem
    By JimSmith94 in forum Android 4.4 KitKat
    Last Post: 07-21-2014, 04:32 PM
  3. Problem connecting Note 3 to PC
    Last Post: 07-16-2014, 09:54 PM
  4. Quick settings Problem
    By Kareem_H_A in forum Samsung Galaxy S4 Active
    Last Post: 07-15-2014, 08:47 PM
  5. HTC One X Multiple problems
    Last Post: 07-15-2014, 02:36 PM
