1. elykoj's Avatar
    100% charge of the battery, with minimal usage.. drained 32% in 4 1/2 hours with power saving enabled. that dont seem right does it????
    07-16-2014 02:17 PM
  2. mhunter6378's Avatar
    No it doesn't seem right. Post some screenshots of your battery stats...
    07-16-2014 02:26 PM
  3. Zakariya Talab's Avatar
    I once encountered a problem like this about 4 weeks into having the phone, but after a day or disappeared, since then ove had amazing battery life usually about 7 hours on screen time. I think this issue is just a hickup the battery has when it's new it should go away soon.
    07-19-2014 04:47 PM
  4. AZgl1500's Avatar
    Allow the battery to run down to about 10%
    Then give it a 24 hour, or at least, an overnight charge from the OEM 2.1 amp USB 3.0 cable charger module.
    That should re-establish the battery's charge rate.
    Now, turn the phone off, and then power it back up.
    Report back to us, it should be okay.
    07-19-2014 06:19 PM
  1. HTC One stuck in bootloop, can't connect to PC
    By ughazi93 in forum AT&T HTC One
    Last Post: 06-30-2015, 02:50 AM
  2. Longer battery life & longer charge time 4.4
    By mty msi in forum AT&T Galaxy S III
    Last Post: 07-24-2014, 12:54 PM
  3. Replies: 6
    Last Post: 07-16-2014, 04:20 PM
  4. PC to tablet installing
    Last Post: 07-16-2014, 01:57 PM
  5. My phones charges slow now?
    By Natee in forum Samsung Galaxy S4
    Last Post: 07-16-2014, 01:30 PM
