Results 1 to 19 of 19
    Default Battery Drain
    Can you guys help me out and tell me why these are killing my battery. My battery used to be so good and don't know what happened. Click image for larger version.
  2. #2
    Default Re: Battery Drain
    Quote Originally Posted by Shawn0813 View Post
    post up your on screen time. do you have sync on?
    Shawn0813 likes this.
    Good catch sync was on..... Click image for larger version.
  4. #4
    I am a control freak guy....
    When I am not using my phone, I turn off the internet.
    ie, no data, wifi, sync, nada......
    that stops just about everything from sucking your battery dry.
    I leave the gps on high accuracy mode, I have found that to have negligible effect on overall battery life.
    doing it that way you will get very good battery life..... all day long and still have 85-90% left at the end of the day.... until you turn ON access to the internet..
    That is when the battery starts getting sucked dry.
    video streaming, music streaming, etc... online games, etc...
    Thanks for the input. I used to get over 4 hours screen on time with no problems. I will try some of the above. How many hours do you normally get with screen on time?
  6. #6
    gottria's Avatar
    Posts
    Global Posts
    670 Global Posts
    For having 28% left and almost 14 hours since last charge, I don't think that is too bad. Of course I'm still fairly new to the S5 but still learning.
  7. #7
    This is mines few days ago I posted in another thread...
  8. #8
    If you have one, I guarantee that it's sd card related.
    Back it up, format it on the phone then put your files back on it.
    That's impressive
  10. Thread Author  Thread Author    #10
    I tried some of the tips mentioned above and heres screenshots of yesterdays battery life. I had to charge a little to turn phone on.
ID:	128433Click image for larger version.
  11. #11
    You should post your max screen on time again without the charger on.
    Your screen on time is too good to be true. These phones max on screen time should be around 7 hour-ish.
  12. #12
ID:	128550Click image for larger version.
ID:	128551 here are mine as of this evening. Android System is still at the top of my list
  13. #13
    I also have battery drain. There's also like 50 or more processes running in the background. Is this normal?
    Attached Thumbnails Attached Thumbnails Battery Drain-screenshot_2014-07-21-14-59-31.jpg   Battery Drain-screenshot_2014-07-21-14-59-53.jpg
  14. #14
    you need to upload your on screen time. otherwise we don't know how to judge it..
  15. Thread Author  Thread Author    #15
    Thanks to pain fx my battery seems to be working a lot better. The 2 biggest turn arounds were turning sync off and when using WiFi turning mobile data off.
  16. #16
    that's what i do also to achieve long battery life.
  17. #17
    I'm having some similar issues. Last night I went to sleep with the phone at about 55%, woke up at 25%. I can get two days out of it, sometimes. It just depends on things I don't know. But today, it seemed to die rather quickly. I did download a few app updates, but not much else. I'm using Nova Launcher Prime.
    Today, as it sits, its at 40% with 12h 40 min on the batt,
    22% Screen with 1hr 2 min on time
    Android System 19%
    Android OS 15%
    Cell Standby 8%
    WiFi 5%
    Device Idle 5%
    Then down from there. (sorry for no screen caps, having a hard time getting them to sync up to post)
  18. #18
    Instagram is killing my battery
    Attached Thumbnails Attached Thumbnails Battery Drain-screenshot_2014-07-22-11-43-38.jpg
  19. #19
    Turning off "smart network switching" and "sync" seems to be helping a lot with my previous battery drain problem.
  1. Note 3 battery drains really quickly
    By jr92897 in forum Samsung Galaxy Note 3
    Last Post: 04-08-2015, 08:11 PM
  2. battery drain after update
    Last Post: 08-23-2014, 08:58 PM
  3. extended batteries
    By jneusch in forum LG G3
    Last Post: 08-12-2014, 07:15 PM
  4. s5 battery draining very very fast !!!!
    By Solo 8 in forum Ask a Question
    Last Post: 07-18-2014, 04:32 PM
  5. G3 External Battery Charger?
    By MasterRy88 in forum LG G3
    Last Post: 07-18-2014, 02:41 PM
