Results 1 to 3 of 3
    chelsea_avery's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default samsung galaxy s5 notification sound problem!
    I've had my galaxy for about 2-3 weeks and the notification sound whenever I receive a text message or Facebook chat or whatever isn't happening. No noise is being played when it is on sound mode, it just vibrates. When I click to listen to the preview of another notification tone (I assumed there was something wrong with the certain tone ) no sound played! So it won't even play the preview for my notification sound. My ring tone and alarm sounds work fine though. Help!!!
  2. #2
    warn joe's Avatar
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: samsung galaxy s5 notification sound problem!
    Quote Originally Posted by chelsea_avery View Post
    Well, Try holding the volume up button a pop up will be shown which shows that volume is increasing and over the side there's a settings icon click over it will show you the volumes for different.... make sure you move all the slider to the max. Once you did that now check if your device still vibrates or this time it rang up !! If again this time it doesn't rang up then I would say try visiting the customer support !
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for your quick reply! Yeah I've already tried that and nothing happened silly question but should I call my network provider customer support or samsung customer support?
  1. Replies: 35
    Last Post: 11-10-2014, 12:00 AM
  2. Replies: 1
    Last Post: 07-23-2014, 02:30 PM
  3. How to update Androis 2.3.6 on samsung gt-s5570i
    Last Post: 07-23-2014, 10:06 AM
  4. phone problems
    By idekokay in forum Ask a Question
    Last Post: 07-23-2014, 07:20 AM
  5. i tryed to flash the stock rom for my samsung s5 and then...
    By Jan Buchmeier in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 07-23-2014, 03:57 AM
