Problem connecting my new Samsung Galaxy 5S via Bluetooth with my Jabra Freeway car speakerphone. In short, my 5S does not recognize my Jabra. Suggestions please? I haven't had problems connecting Jabra with other smartphones so I am truly puzzled. Thx.
Have you checked on the Jabra website if the 5S was compatible with the Freeway (or vice-versa)?
Start with putting the Freeway into pairing mode and follow the instructions (which will tell you to go
to go to the bluetooth menu on your phone and search for a new device.
* make sure you pay attention to your phone during this process as it will prompt you for permissions needed for the Freeway.
Also, make sure you download Jabra Assist to help with the text readout functions.
Hope this helps.
