1. Tyler_13's Avatar
    Hello, when I put my s5 into ultra power saving mode it will start to restart itself lots and doesn't like to disable when I try to
    sent from my galaxy s5 using tapatalk.
    07-29-2014 03:21 PM
  2. Tyler_13's Avatar
    Anyone?
    09-30-2014 10:28 AM
  3. Umass021's Avatar
    I haven't had that issue yet and I have used power saving mode a lot.
    09-30-2014 10:30 AM
  4. CKR83's Avatar
    I tried powersaving mode for a short time after I got the phone. Seemed to slow things down too much (I didn't know about unchecking the processer speed setting when I tried it), but I never had the reset problem. Are you sure the phone's not overheating?
    Also, I found as I tweaked the phone that I don't really need power saving mode. I might if I was going on a trip or something, but for daily use, I get more than enough battery out of the device to not have to use powersaving.
    09-30-2014 10:53 AM
  5. Tyler_13's Avatar
    In standard power saver phone works good but in ultra power saving mode it will keep restarting itself for no reason. I don't use it a lot but here and there when battery is low and can't get to a charger but it's useless cause the restarting kills it quicker
    09-30-2014 11:01 AM
  6. CKR83's Avatar
    Hmmm. Don't know how to help you with that one. I have limited experience on a lot of this stuff.
    09-30-2014 12:20 PM
  7. james62370's Avatar
    Usually this is caused by Xposed with the Wanam Xposed Module enabled. Try disabling Wanam Xposed, then reboot before going into Ultra Power Savings Mode. Good luck!!
    08-10-2015 05:19 PM
  8. Kaiba Redfox's Avatar
    Has anyone found an answer to this my phone is stuck in the same position please help
    07-19-2016 11:33 PM
  1. Samsung S5 Facebook Photo Issues- White screen, no pics
    Last Post: 09-10-2014, 02:47 PM
  2. camera/image processing issue? [Help wanted]
    By Dre-Sean in forum Samsung Galaxy S5
    Last Post: 07-30-2014, 05:40 PM
  3. Return S-Off Dev Edition to Amazon without issues?
    By y2jdmbfan in forum HTC One M8
    Last Post: 07-30-2014, 01:35 PM
  4. Can't save Farorites on YouTube App!!
    Last Post: 07-29-2014, 03:43 PM
  5. Replies: 1
    Last Post: 07-29-2014, 02:33 PM
