Results 1 to 3 of 3
    srfoot's Avatar
    Posts
    Global Posts
    187 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Sound in silent mode? Alarm.
    Hi;
    Is there a sound in silent mode function. I can not find it.
    My stock alarm is not sounding in the am when I have it set. My phone is in mute mode over night. This used to work but I did a hard reset of my phone and now it doesn't sound in mute.
    If I do a test alarm for a couple of minutes from now it does work.
    I'm unsure of what has changed?
    Thank you.
  2. #2
    warn joe's Avatar
    Banned
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Sound in silent mode? Alarm.
    Quote Originally Posted by srfoot View Post
    Hi;
    Thank you.
    Well, I don't think that there is any problem if you have tested the alarm for a couple of minutes and it was working mean the alarm is working fine its may be you who is sleeping way more deeply and can't hear the alarm :P. One day I was also thinking the same thing that my alarm doesn't went off in the morning but later than when I watch the cctv footage of my house I can hear my device ringing and It was me who is in deep sleep. So I would say that was not the fault of your device :P
  3. #3
    Liz Burns's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My phone is having the same issue after installed most recent update, I set the phone to MUTE at night so I don't get any notifications but the alarm is also muted and doesn't go off, I can't seem to have it both ways other than to turn off all notifications and leave the sound on, which is a hassle to say the least as a "daily ritual" used to work now it doesn't...any ideas?
  1. Sound is full but is low
    Last Post: 08-01-2014, 05:09 AM
