Page 4 of 4 FirstFirst 1234
Results 76 to 91 of 91
Like Tree17Likes
  1. #76
    bIOforger's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy s5 Battery Drain
    Quote Originally Posted by GealB View Post
    To be honest this is simply design flaw, nothing else. I hang around with 4 guys. 3 of us bought Galaxy 5’s from some dude who supplies electronic devices. And all of us complain about the same thing - battery does not last an hour on full charge, alternatively, I plug the device to my Mac at 60% the thing drains down to zero and automatically switches off and start charging again. Original Samsung battery!! Bought a new battery, same story. It is the worst mobile device experience I’ve ever had to face. The phone stays on charge the entire office hours and only lasts and hour.
    It sounds like a joke but I sunk my R6000 on this device 3 weeks ago.
    Only an hour??? lol something seriously wrong there. Oh wait "bought from some dude who supplies eletrical devices" yup that'll be why then lol.
    Jon Jackson likes this.
  2. #77
    RStoychev's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Could someone tell me what is this on top off list...
    Attached Thumbnails Attached Thumbnails Galaxy s5 Battery Drain-1412931426889.jpg
  3. #78
    codyoehl's Avatar
    Posts
    Global Posts
    595 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by RStoychev View Post
    I'm not exactly sure what it is, but I believe you can turn it off
    Under your all apps page, it should be called unified daemon
    Posted via the Android Central App with my Galaxy S5
  4. #79
    HFL
    HFL is offline
    HFL's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    1.lower ure screen brightness
    2.put on battery saving mode
    3. install Task Manager cuz one of samsung is basic.
  5. #80
    morenoa48's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Mirage
    I've searched all over and it seems there are plenty of people having battery drain issues but have yet to find the exact cause and solution. In my case, my phone worked perfectly for about 3 months, then the battery started to drain dramatically with no change as far as use or applications installed. Losing about 5% to 10% an hour just sitting idle. A restart will temporarily fix the issue for about a day (lately a few hours). I have done factory reset, pulled battery, drained completely and recharged. Nothing has worked. This has been ongoing for about two weeks. Since most of these discussions just seem to abruptly end without stating any solution (fix, returning phone or switching to iPhone), maybe the problem goes away by itself...?
    By the way...disabling wifi, data, lowering brightness, changing launcher, and even power saving mode (regular not ultra) did not help.
    -Galaxy S5 Sprint 4..4.2 Stock
  6. #81
    bbmjack's Avatar
    Posts
    Global Posts
    811 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah and your battery gets 65 Celsius
    using SM-G900H KNOX WARRANTY VOID 0X1
    I9505 WARRANTY VOID 0X0 in vacation
  7. #82
    mklasse's Avatar
    Posts
    Global Posts
    59 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi, I have been using Galaxy S5 for a few months now, the first 3 months, the battery life was great. Lately I can't even get through the day without recharging mid-day. Opening the battery statistic, there is this process called gpsd, and it was never shown before.
    I dug deeper into gpsd online, and it said an app maybe triggered the process.
    I have tried:
    Turning off location, uninstalling apps that recently updated that has location access.. nothing. So I did factory reset and have not installed no 3rd party apps yet, but the gpsd shown up already.
    I am getting so frustrated now, Any idea what could be the culprit?
    I can't install wakelock app since the phone had to be rooted, and in my country, rooted phone = warranty void
  8. #83
    Northern.dj's Avatar
    Posts
    Global Posts
    169 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok I think I have seen what it could be if you look at the system apps and look at the non samsung system apps that are running.
    This is how networks hide there rubbish
    So when this happens the finger does not point at them
  9. #84
    AZgl1500's Avatar
    Posts
    Global Posts
    1,962 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mklasse View Post
    I have tried:
    Since you have done a factory reset, you don't have much on it except for Vendor bloatware.
    Open the App Drawer (the block of grids, lower right corner of phone)
    Uninstall/Turn OFF all of the extraneous apps not needed to make the phone work as a phone. That will be most of them.
    Long Press, drag to top and drop onto Uninstall icon.
    No harm will be done, all of this can be undone by turning them back ON later.
    I've had my phone since 4/11 and always leave the GPS 'on' and in High Accuracy Mode.
    I also use MacroDroid to turn the internet (WiFi & Data) OFF when the screen is locked.
    When the screen is Unlocked, MD turns the internet back ON.
    If my phone is idle and unused, it will literally only use about 8% battery per day, that is more than six (6) days of idle standby time with the internet turned off. The phone still receives calls and SMS, so I have lost nothing during this internet OFF time.
    The phone is never warm to the touch. The only time it ever gets a little warm is when laying on the Qi wireless charger pad.... but, after about 4 hours, the phone is fully charged and cools down again.
    As I suggested, turn off all apps you don't need, test to see if your phone works normally at that point.
    Also, manually turn off the WiFi and Data feature, and watch the phone in idle mode. I suggest that this will stop your battery drain problem.
  10. #85
    mklasse's Avatar
    Posts
    Global Posts
    59 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by AZgl1500 View Post
    I did everything with no avail.. and it turned out my network provider (Indosat) that has caused the gpsd problem.. it was weird as I have used the same provider since the day I bought my galaxy S5. It only caused problem now, approx.3 months after the purchase. The problem only occurred if I activate mobile data. If I deactivated mobile data and restart the phone, the problem dissapeared. Once I activate mobile data (even on wifi), gpsd instantly re-appeared, and the phone will never get into deep sleep mode.
    I have bought a couple of pre-paid sim from different providers, and found no problem on gpsd drain. My mom is also using Indosat, so I have also tried using her sim, just in case my sim card is defective, and gpsd problem instantly re-appeared. So I am guess it wasn't because of defective sim card.
    I have tried asking local forums for those who are using Galaxy S5 on Indosat network, and so far only 5 people has responded, and 3 of them has gpsd issue, while the other 2 is fine. Weird. My cousin is also on Indosat but her phone is Lenovo K900, she did not have gpsd issue.
    I have tried contacting Indosat by phone and e-mail, no solution is given until now, they did not even reply my e-mail.
    Anyway, I have switched provider now, and gpsd problem never resurfaced ever since, and my battery life is great now.
  11. #86
    dgrobe2112's Avatar
    Posts
    Global Posts
    172 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hey guys.. i have had my phone over 6 months now.. and had good battery life. now, it wont go half a day. take off the charger in the morning, like i always do, listen to music at work, like i always do, except now, the last week or 2. the battery is just about dead at lunch. never happened before.
    the battery stats show "phone" as the culprit. whats up with that. i have never seen phone even show up on my list.
    off charger for 4 hours 30 mins. battery down to 47%.
    Phone is 47%
    screen 21%
    AndroidOS 8%
  12. #87
    AZgl1500's Avatar
    Posts
    Global Posts
    1,962 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dgrobe2112 View Post
    Phone is 47%
    screen 21%
    AndroidOS 8%
    Are you using the stock dialer?
    I have tried a couple of dialer apps and not all of them are well behaved and you need to close them out.
    Personally, I went into Develper Options and have clicked the "Close apps when user is through with them" box and the dialer now exits correctly. This does NOT remove that item from the Recent List, it just closes the app.
    I am now using exDialer in tandem with the OEM dialer.
    Each has its' own advantages. I go back 'n forth on occasion.
  13. #88
    sidepipe's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There are probably loads of reasons for battery drain... definitely some apps etc can cause issues, as can a poor signal etc... though unless you want it to last for days you shouldn't have to turn off mobile data, location services, bluetooth, etc etc.
    I've been having an annoying battery drain issue not related to any of the above. In fact, even UPSM didn't help, so clearly not an app problem. The phone would be fine for weeks, and then for no ( apparent ) reason would start using 7%+ an hour even when idle. A factory reset cleared the issue, but it would come back again after a random time after ( seemingly ) no changes to its set-up. Yesterday though I may have finally figured it out.
    The battery drain issue started after I'd not fully charged the phone. Normally, I put it on charge every night and so it's always at 100% at the start of the day. However, I was in a hotel with no convenient power socket, and wanted to use the alarm, so left it off charge until the morning. It started at around 50%, I charged it for about 45 minutes ( after which it was saying 72% ) and then unplugged it again. This was at about 9.30am, but by 7pm the battery was down to 16%.
    As an experiment, I switched the phone off and charged it ( rather than leaving it on. ) The battery charge went up to 99% pretty quickly, but then stayed on 99% for about half an hour before finally saying it was charged. Today it's been fine again ( on 91% now after 5 hours on battery. ) So, the jury's still out on whether this is a real fix for my particular issue, but if it is then it lends credence to the theory that the battery calibration can be affected if the phone isn't fully charged, and maybe it's just that the electronics were cutting off the battery charge way before it was at 100% ( even though it was showing 100% on the phone. )
  14. #89
    Ricciardo Turner's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi All,
    I read this in another post somewhere and it appears that "Location" is the culprit for the battery drain problems everyone is having. This simple solution worked for me as well as the original author.
    1. Turn off "Location" and restart phone (If not already on, turn on for 10 minutes and then turn off again before restart)
    2. Turn "Location" back on and restart phone.
    This should fix the battery drain problem. It appears that "Location" gets "stuck" and is constantly searching even when your phone is sleeping and just needs a refresh every now and then.
    konvajw likes this.
  15. #90
    AZgl1500's Avatar
    Posts
    Global Posts
    1,962 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If all else is okay,, Location being on does not hurt the battery.
    The GPS on activates when another app polls it asking for 'location'
    My location is on all the time, GPS only.
  16. #91
    Lawtse's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I resolved the battery drain problem by resetting the phone and I stopped using the finger print scanner and now the phone works fine
  1. galaxy tab4 remove promo screensaver
    Last Post: 09-07-2016, 01:44 PM
  2. 32GB Samsung Galaxy Tab S 10.5 Bundle
    By 05GT in forum Marketplace Archive
    Last Post: 09-30-2014, 10:43 AM
  3. Galaxy S4 not working after screen repair.
    By Noodles42 in forum Ask a Question
    Last Post: 08-02-2014, 06:40 PM
  4. Samsung galaxy s4 Signal drop
    Last Post: 08-02-2014, 05:08 PM
  5. samsung galaxy s4 screen glass replacement
    Last Post: 08-02-2014, 04:08 PM
