Results 1 to 12 of 12
Like Tree11Likes
  • 1 Post By B. Diddy
  • 1 Post By WBSnow
  • 1 Post By bbmjack
  • 2 Post By B. Diddy
  • 3 Post By Golfdriver97
  • 2 Post By Golfdriver97
  • 3 Post By peacefulberry
    WBSnow's Avatar
    Posts
    Global Posts
    185 Global Posts
    Default Battery Pull (Automatically or Simultaneous)
    Greetings. I'm not great with naming my topics but here's my question. I came from BlackBerry to Samsung and remember older BlackBerry devices being able to set my device to turn off and then turn on at specific times. There was also an app on my old BlackBerry that would simulate a battery pull.
    I'd like the ability to turn off then turn on my device automatically. Are there any apps available for the Samsung Galaxy S5 that can do either?
    Thank you.
  2. #2
    Default Re: Battery Pull (Automatically or Simultaneous)
    Is there a reason why you want to do this? It's not really necessary on Android devices, although some people like to power off and power back on every few weeks.
    WBSnow's Avatar
    Posts
    Global Posts
    185 Global Posts
    I'm use to powering off my smartphones daily to 'connect' to the wireless network, reset the device or clear the cache. I was told this by AT&T which was the same thing I was told by Verizon when I was on their network.
    I'm new to Android, and learning. I've read both sides to this and guess I'm set in my ways.
  4. #4
    In my experience, powering down is not necessary unless you start noticing some odd behavior from the device. I can't remember the last time I powered down my Nexus 5, especially now that we don't have to any more on planes!
    Hopefully this guide might be useful to you! http://forums.androidcentral.com/gen...id-2014-a.html
    WBSnow likes this.
    WBSnow's Avatar
    Posts
    Global Posts
    185 Global Posts
    P. Diddy, thank you for your help. I appreciate it.
    I have a Samsung Galaxy S5.
    B. Diddy likes this.
  6. #6
    bbmjack's Avatar
    Posts
    Global Posts
    811 Global Posts
    It's B not P
    Aquila likes this.
  7. #7
    Heh heh, no worries. I get P. Diddy, B. Duddy, Big Daddy ... 😃
    peacefulberry and WBSnow like this.
  8. #8
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,707 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Quote Originally Posted by B. Diddy View Post
    Heh heh, no worries. I get P. Diddy, B. Duddy, Big Daddy ... ������
    I get Golddriver every now and then....lol
  9. #9
    Posts
    Global Posts
    32,707 Global Posts
    Carrier
    To stay on topic, though:
    For most of my devices, I rarely power down my device as well. I clear my cache in recovery once per month, so that alone covers my need to power down the device. The only time I do shut my phone off is when I ma experiencing issues that I believe a shutdown will solve, which isn't very often.
    For my daily driver, my M8, I am on a nightly version of Liquid, so that can potentially get turned off more often as I update once per week.
    For the average user: A shutdown every day isn't required. It won't really hurt, but I also don't see much benefit behind it either.
    WBSnow and B. Diddy like this.
  10. Thread Author  Thread Author    #10
    WBSnow's Avatar
    Posts
    Global Posts
    185 Global Posts
    Oops, I made a mistake. B. Diddy, thank you!
  11. #11
    Quote Originally Posted by WBSnow View Post
    Thank you.
    I had blackberry in the past and boy do l remember the battery pulls! Lol. The only reason you would need to do that is if you have a frozen screen or something else wrong like they said above. If you want to clean some of your cache, just go to settings, more settings, storage, then click on cached data, then ok. To clear your partition cache, you have to reboot into recovery mode. The steps maybe a little different for your model, but there's plenty of info here if you need extra help. Golf and B. are great!
  12. #12
    There isn't a really good reason to 'pull the battery' or restart the phone.
    But, if you just want to play around with doing things like that, and other neato tricks,
    download MacroDroid and look at what it can do.
    The only thing it can't do is what your imagination can't figure out.
    * MacroDroid - Device Automation - Android Apps on Google Play
  1. Replies: 1
    Last Post: 09-01-2014, 01:20 PM
  2. LG G3 or Galaxy S5?
    By RavenSword in forum General News & Discussion
    Last Post: 08-22-2014, 09:25 PM
  3. Replies: 1
    Last Post: 08-03-2014, 12:33 AM
  4. Replies: 3
    Last Post: 08-02-2014, 10:05 PM
  5. Replies: 2
    Last Post: 08-02-2014, 08:30 PM
