Hi folks I found way to fix battery drain happens in samsung s5
1. The main reason is Google+ this app back up pictures , why it drain battery , because it's using data so much happened to me wasted 2 GB quota one hour
NOW The FIX is :
go to application manager , go to all , then find google+ and then turn off MAKE SURE TURN OFF NOT FORCE STOP
IF ROOTED : download app master then delete google+
Done I'm happy with battery life
Comment below your opinions
Edit:
Or sign out
NOW The FIX is :
Edit:
Or sign out
